MicroCode Studio Plus Code Explorer Question
Results 1 to 2 of 2
    Jul 2005
    Palmdale, CA
    Default MicroCode Studio Plus Code Explorer Question
    The help file says you can locate variables, constants, defines, etc by clicking on the name in the code explorer. When I do this, it goes to the first instance of the name in my code which is usually where the variable, constant, or what ever, is declared. I can't seem to search any farther with it. Is this the way it works? I would like to be able to search the code for all instances of the item using the code explorer. Is this p[ossible?
    Ed
    Feb 2005
    Essex, UK
    I usually use the "find" located under the Edit menu or by clicking on the binocular icon at the top. Alternatively, ctrl + F will do the trick.
    I don't think there is away to locate or highlight specific variables etc by using the code explorer - this only locates where the variable or constant was defined.
    HTH
    Rob
  1. 16F877A Microcode Studio won't compile
    By curt66111 in forum mel PIC BASIC Pro
    Last Post: - 25th November 2009, 20:35
  2. pic18f series and microcode studio
    By ahm2002 in forum mel PIC BASIC Pro
    Last Post: - 10th December 2008, 20:35
  4. Microcode studio and USB pics
    By KPDes in forum mel PIC BASIC Pro
    Last Post: - 27th May 2007, 10:28
  5. Setting Fuses using Microcode Studio Plus
    By NO2K in forum mel PIC BASIC Pro
    Last Post: - 19th May 2007, 00:14
