Help with code, settings
Results 1 to 5 of 5
    malc-c's Avatar
    malc-c Guest
    If you are are using MPSAM and you have the correct chip selected in MCS then try
    @ __CONFIG _INTRC_OSC_NOCLKOUT & _WDT_ON & _PWRTE_ON & _MCLRE_OFF & _BODEN_ON
    and then add then line
    DEFINE OSC 20
    See if that works
    Feb 2005
    Essex, UK
    Question
    is it not compiling correctly or is it that portb.2 isn't toggling in your circuit?
    if it's that it's not working in your circuit, it could be a couple of things; no pull-up resistor on MCLR, oscillator not correct or not functioning correctly (capacitors), RB.2 not set to digital or not set to an output
    Cheers
    Rob
  1. Simple LCD code not working!...WHY?
    Last Post: - 29th November 2009, 20:48
  2. Reading in Manchester code
    By brid0030 in forum Code Examples
    Last Post: - 10th March 2009, 22:55
  3. How much code space do PBP statements use.
    Last Post: - 13th February 2009, 22:31
  4. Loop with two motor and 2 sensors
  5. Making Program Code Space your playground...
