Help with code, settings
Results 1 to 5 of 5
    Jul 2007
    Default Help with code, settings
    I cant get this code to work with my PIC16F887 :/
    @   device  pic16F887, hs_osc, wdt_off, mclr_on, lvp_off, protect_off
    DEFINE OSC 20
    loop:
    high portb.2
    low portb.2
    goto loop
    Im not 100% sure if this is right, is it?
    malc-c's Avatar
    malc-c Guest
    If you are are using MPSAM and you have the correct chip selected in MCS then try
    @ __CONFIG _INTRC_OSC_NOCLKOUT & _WDT_ON & _PWRTE_ON & _MCLRE_OFF & _BODEN_ON
    and then add then line
    DEFINE OSC 20
    See if that works
    Feb 2005
    Essex, UK
    Question
    is it not compiling correctly or is it that portb.2 isn't toggling in your circuit?
    if it's that it's not working in your circuit, it could be a couple of things; no pull-up resistor on MCLR, oscillator not correct or not functioning correctly (capacitors), RB.2 not set to digital or not set to an output
    Cheers
    Rob
    Quote Originally Posted by xobx View Post
    DEFINE OSC 20
    loop:
    high portb.2
    low portb.2
    goto loop
    For PM assembler use:
    @ DEVICE  PIC16F887, HS_OSC
    @ DEVICE  PIC16F887, WDT_OFF
    @ DEVICE  PIC16F887, MCLR_ON
    @ DEVICE  PIC16F887, LVP_OFF
    @ DEVICE  PIC16F887, PROTECT_OFF
    For MPASM use:
    @ __config _HS_OSC & _WDT_OFF & _PWRTE_ON & _LVP_OFF & MCLR_ON, & PROTECT_OFF
    SEE THIS THREAD: http://www.picbasic.co.uk/forum/show...iguration+fuse
    Default Using a bootloader??
    If you are using a bootloader you need something like
    DEFINE Loader_Used 1
    near the top of your program
    HTH
    Brian
  1. Simple LCD code not working!...WHY?
    Last Post: - 29th November 2009, 19:48
  2. Reading in Manchester code
    By brid0030 in forum Code Examples
    Last Post: - 10th March 2009, 21:55
  3. How much code space do PBP statements use.
    Last Post: - 13th February 2009, 21:31
  4. Loop with two motor and 2 sensors
  5. Making Program Code Space your playground...
