16F877A won't keep relay on 100% of the time
Results 1 to 21 of 21
    Las Vegas, Nevada, USA
    Default Work around found
    With a terrible hiccup in the 12kHz signal, I have to test the the frequency with:
    If (Counter > 1) then
    So as long as the PIC counts anything over a 1kHz, the relay works properly. What a crappy 12kHz signal from Mach3. I hope this doesn't reflect the quality of their stepper motor control. I guess I'll find out.
    Hopefully, they the explanation is that they had to compromise the 12kHz signal for better control over the stepper motor signals.
    Feb 2005
    Essex, UK
    Quote Originally Posted by coyotegd View Post
    I'm not familiar with the Mach3 product but it sounds like it needs to be corrected as it's not offering a correct output. If you need to use it you could always try this in your code:
    working var byte
    working = 2
    MAIN:
    count chrgpmp, 1, cntcp ' Count freq. on B0, Mach3's 12kHz
    if (cntcp >= 11) and (cntcp <= 13) then ' Freq. must be between 11 & 13kHz
    working = 2
    if working > 0 then      ' Stops working variable from rolling from 0 to 255!
    working = working - 1
    if working >0 then
    lptports = 1
    lptports = 0
    This will make a double check every time there is a 'hiccup' in the 12kHz signal. Of course if this doesn't correct it you could always increase the "working" variable where it is defined and also in the third line of the above code.
    Hope this helps
    Rob
    Default Does the power supply sag?
    From the symptoms described, I would be looking (with a scope) at the power supply. If the 5V relay draws slightly more current than the power supply can sustain then I would expect BrownOut Resets some short time after the relay energises.
    Just a thought.
    Brian
  1. First time with external oscillator - 16F877a Not working
    Last Post: - 15th October 2009, 17:14
  2. I don't understand this code!
    Last Post: - 13th February 2008, 02:55
  3. Serial Relays
    By tazntex in forum General
    Last Post: - 17th May 2007, 17:42
  4. Serout2/serin2 Pbp Problem
    By SOMRU in forum mel PIC BASIC Pro
    Last Post: - 11th December 2006, 19:55
  5. Timer in real time
    By martarse in forum mel PIC BASIC Pro
    Last Post: - 29th July 2005, 14:24
