You are right, but A2 is correct. When I first posted, I change my code for clarity. I probably should have used the exact same code all the way through. When I said A1 earlier, it should have been A2. Good find. Thanks for looking.
I think everyone should STOP TRYING TO FIGURE THIS OUT. I tested the programmed PIC with a breadboarded darlington and relay and it works like a champ. No split-second low on A2 approximately every second during a proper A2 high when B0 frequency is between 11 and 13kHz.
I must have a conflict in my power supply or other PIC peripheral connections. I'm sure I'll find the answer when I look very closely at my schematic.
Thanks everyone.
