Tristated output to two common Base transistor issue
Results 1 to 40 of 55
Threaded View
  1. #35
    Italy
    Quote Originally Posted by RussMartin View Post
    Exchanging the positions of R6 with D1 and R5 with D2 in Alain's version
    will accomplish the same result, but without the voltage divider.
    Hi Russ,
    This is not possible because on the original board made by Roger,
    the anode of one LED is connected to the cathode of the other LED.
    The purpose of the voltage divider was to keep the board as it is.
    (The voltage divider can be made by adding one wire to the board).
    Best regards,
    Luciano
  1. Help changing CCP3 output pin
    Last Post: - 15th July 2008, 03:30
  2. Bit Banging input to output on PIC16F876A
    By Bronurstomp in forum mel PIC BASIC Pro
    Last Post: - 26th June 2008, 20:50
  3. Serious Serial Situation Setbacks...
  4. Using LEDs as light sensors
    Last Post: - 30th December 2006, 23:19
  5. HSEROUT Newbie question/problem
    By Mark Scotford in forum mel PIC BASIC Pro
    Last Post: - 11th July 2006, 15:44
