Tristated output to two common Base transistor issue
Results 1 to 40 of 55
    Omaha, Nebraska USA
    Scratch this post.
    Russ
    N0EVC, xWB6ONT, xWN6ONT
    "Easy to use" is easy to say.
    Italy
    Hi Russ,
    These are the test results. I have used the old transistors
    and also new transitors but the results are the same. The
    picture below is with the new transistors.
    The picture shows the two LEDs ON with about 25% luminous intensity.
    Best regards,
    Luciano
    Italy
    With the circuits we are exploring here, the two LEDs are turned OFF by setting
    the I/O of the PIC as input. (Input tristated). When the I/O is set as input,
    the voltage present on the I/O pin must be recognized as logic LOW or as a
    logic HIGH. Undefined voltage levels are dangerous for the input buffer of the I/O.
    Floating inputs on digital pins are a no-no.
    Best regards,
    Luciano
    Omaha, Nebraska USA
    Thanks for an excellent result! (And the photo!) And thanks for bearing with me . . . I'm doing this on paper, not on a breadboard. I don't know what your LEDs are, so I'm having to guess at the Vf (I'm using 1.6 V) and assuming an If of 20 mA.
    If you please, try increasing both Rcl's each by the same amount until the LEDs just go out, then test high and low at Rb again.
    I appreciate your concern about floating inputs, but we can deal with that next. (I have something in mind.)
    Russ
    Just to throw a little confusion in the mix, .... how bout ....
    <table border=1><tr><td><img src="http://picbasic.co.uk/forum/attachment.php?attachmentid=1994&stc=1&d=118930280 7"></td><td>
    Or, it may need a normal NPN
    <img src="http://picbasic.co.uk/forum/attachment.php?attachmentid=1995&stc=1&d=118930343 1"></td></tr></table>
    Also just on paper
    How about something like this?
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    Italy
    Hi Bruce,
    Here are the results:
    When Tab is open the whole circuit uses 1mA.
    I have used 3 transistors BC558.
    Thank you!
    Best regards,
    Luciano
    P.S.
    Do not connect LEDs in parallel like that with just one series resistor!
    If you need to connect LEDs in parallel, use one resistor for each LED.
    This was just a quick test to see if 50mA were available.
  1. Help changing CCP3 output pin
    Last Post: - 15th July 2008, 03:30
  2. Bit Banging input to output on PIC16F876A
    By Bronurstomp in forum mel PIC BASIC Pro
    Last Post: - 26th June 2008, 20:50
  3. Serious Serial Situation Setbacks...
  4. Using LEDs as light sensors
    Last Post: - 30th December 2006, 23:19
  5. HSEROUT Newbie question/problem
    By Mark Scotford in forum mel PIC BASIC Pro
    Last Post: - 11th July 2006, 15:44
