Tristated output to two common Base transistor issue
Results 1 to 40 of 55
    Italy
    Hi Russ,
    The transistors are still working.
    With this circuit the LEDs are always ON.
    NPN BC546
    http://www.fairchildsemi.com/ds/BC/BC546.pdf
    PNP BC558
    http://www.fairchildsemi.com/ds/BC/BC558.pdf
    Best regards,
    Luciano
    Italy
    Hi Russ,
    My interest was to find a solution for the LEDs board that Roger has already made.
    If there is no solution for the original LED board, then a new board with I/O port
    expanders ICs + transistors is in my opinion the way to go.
    (One I/O + 1 transistor for each 50mA LED). That way all the LEDs can be
    ON at the same time and each LED can be individually controlled.
    Best regards,
    Luciano
    Omaha, Nebraska USA
    Quote Originally Posted by Luciano View Post
    Well, that's good news!
    If you have a few extra minutes, try the circuit this way:
    <IMG SRC="http://www.picbasic.co.uk/forum/attachment.php?attachmentid=1992&stc=1&d=118928211 2">
    Let us know how that comes out. You may want to tinker with the values for Rcl, maybe starting with something between 100 and 150 ohms.
    Do you have some small-signal P-channel and N-channel MOSFETs laying around?
    Russ
    N0EVC, xWB6ONT, xWN6ONT
    "Easy to use" is easy to say.
    Omaha, Nebraska USA
    Scratch this post.
    Russ
    Italy
    Hi Russ,
    These are the test results. I have used the old transistors
    and also new transitors but the results are the same. The
    picture below is with the new transistors.
    The picture shows the two LEDs ON with about 25% luminous intensity.
    Best regards,
    Luciano
    Italy
    With the circuits we are exploring here, the two LEDs are turned OFF by setting
    the I/O of the PIC as input. (Input tristated). When the I/O is set as input,
    the voltage present on the I/O pin must be recognized as logic LOW or as a
    logic HIGH. Undefined voltage levels are dangerous for the input buffer of the I/O.
    Floating inputs on digital pins are a no-no.
    Best regards,
    Luciano
    Omaha, Nebraska USA
    Thanks for an excellent result! (And the photo!) And thanks for bearing with me . . . I'm doing this on paper, not on a breadboard. I don't know what your LEDs are, so I'm having to guess at the Vf (I'm using 1.6 V) and assuming an If of 20 mA.
    If you please, try increasing both Rcl's each by the same amount until the LEDs just go out, then test high and low at Rb again.
    I appreciate your concern about floating inputs, but we can deal with that next. (I have something in mind.)
    Russ
    Just to throw a little confusion in the mix, .... how bout ....
    <table border=1><tr><td><img src="http://picbasic.co.uk/forum/attachment.php?attachmentid=1994&stc=1&d=118930280 7"></td><td>
    Or, it may need a normal NPN
    <img src="http://picbasic.co.uk/forum/attachment.php?attachmentid=1995&stc=1&d=118930343 1"></td></tr></table>
    Also just on paper
  1. Help changing CCP3 output pin
    Last Post: - 15th July 2008, 03:30
  2. Bit Banging input to output on PIC16F876A
    By Bronurstomp in forum mel PIC BASIC Pro
    Last Post: - 26th June 2008, 20:50
  3. Serious Serial Situation Setbacks...
  4. Using LEDs as light sensors
    Last Post: - 30th December 2006, 23:19
  5. HSEROUT Newbie question/problem
    By Mark Scotford in forum mel PIC BASIC Pro
    Last Post: - 11th July 2006, 15:44
