Tristated output to two common Base transistor issue
Results 1 to 40 of 55
    SWITZERLAND (french speaking)
    Luciano,
    Je dois avoir les yeux dans mes poches, c'est pas possible autrement!
    Nevertheless, it looks not possible to control the LEDs the way I thought I could...
    Roger
    Italy
    Hi Roger,
    Try that:
    If you use standard LEDs, replace the 22 Ohm resistors with 100 Ohm resistors.
    Best regards,
    Luciano
    EDIT: The note about the resistors is only if you use this circuit.
    To drive two standard LEDs (max 20 mA) you don't need transistors.
    20 LED's,... 20 Transistors, 20 Resistors. Start adding diodes, half-watt resistors.... Yuck!
    I think I'd just go with 3 of these
    <table><tr><td><a href="http://www.allegromicro.com/en/Products/Part_Numbers/6277/6277.pdf"><img src="http://www.picbasic.co.uk/forum/attachment.php?attachmentid=1974&stc=1&d=118911366 1"></a></td><td>
    Don't even need resistors on each LED.
    Up to 24V for LED drive.
    Set it for 50ma constant current.
    Shiftout the LED states
    And that's it.
    </td></tr></table>
    http://www.allegromicro.com/en/Produ.../6277/6277.pdf
    About $1.50 each in single quantities.
    <br><br>
    Omaha, Nebraska USA
    Exclamation Current-hungry circuit
    One problem I see with Luciano's suggested circuit is that the two 22-ohm resistors form a voltage divider (!) pulling a maximum of 114 mA (5 volts / 44 ohms = 0.114 amps) when the LEDs are doing nothing. 10 channels of this is 10 x 114 mA = 1.14 amps.
    Russ
    N0EVC, xWB6ONT, xWN6ONT
    "Easy to use" is easy to say.
    Italy
    Wink
    Hi Russ,
    The circuit is for the brake light of a car, so the circuit gets the power
    only when the brake pedal is pressed. Also consider that power is generated
    by the alternator, so this current will also decelerate the car when the driver
    activates the brakes ...
    Best regards,
    Luciano
    Omaha, Nebraska USA
    Quote Originally Posted by Luciano View Post
    The circuit is for the brake light of a car, so the circuit gets the power only when the brake pedal is pressed.
    Aha! Thanks! In that case, Roger should go ahead and give your circuit a try!
    Russ
    Italy
    There are ony two 22 ohm resistors for the 20 LEDs.
    Best regards,
    Luciano
    Omaha, Nebraska USA
    Red face Mea culpa!
    BrianT advised me by private message that I had oversimplified my earlier analysis, and he is right. I looked only at the voltage divider created by the resisitors built into the transistors and neglected to consider the diode drop across the base-emitter junctions of the transistors. The circuit, redrawn, looks like this:
    <IMG SRC="http://www.picbasic.co.uk/forum/attachment.php?attachmentid=1980&stc=1&d=118913663 8">
    With the diode junctions in place (a nominal 0.7 VDC drop across each), two voltages change: At A, 4.3 volts; at C, 0.7 volt. At B, it remains 2.5 volts. Both transistors are still "turned on" if there is no voltage present (a high-impedance state) at B.
    Russ
  1. Help changing CCP3 output pin
    Last Post: - 15th July 2008, 03:30
  2. Bit Banging input to output on PIC16F876A
    By Bronurstomp in forum mel PIC BASIC Pro
    Last Post: - 26th June 2008, 20:50
  3. Serious Serial Situation Setbacks...
  4. Using LEDs as light sensors
    Last Post: - 30th December 2006, 23:19
  5. HSEROUT Newbie question/problem
    By Mark Scotford in forum mel PIC BASIC Pro
    Last Post: - 11th July 2006, 15:44
