Tristated output to two common Base transistor issue
Results 1 to 40 of 55
Threaded View
  1. #12
    SWITZERLAND (french speaking)
    Default "Knight Rider" light
    Well,
    I'm still working on a "Knight Rider" stoplight...
    Because of a extremely narrow space availability inside the original stoplight, I can't add lots of components to the circuit.
    The LEDs have to be powerfull enough to look like, at least, the original bulbs.
    I have made a prototype with "common" LEDs and it works well BUT it is far to weak (... and I have made it with yellow LEDs witch makes it unsuable as stoplight).
    <img src="http://www.picbasic.co.uk/forum/attachment.php?attachmentid=1972&stc=1&d=118910210 0">
    I connected the LEDs like hereunder but this is not longer possible because of the use of transistors (btw this is just the LED connection part). The "curious" disposition of LEDs in this shematic allows me to switch-ON two consecutive LEDs and improve the fluency wipe effect - but this is another story.
    <img src="http://www.picbasic.co.uk/forum/attachment.php?attachmentid=1973&stc=1&d=118910225 7">
    I couldn't find SMD transistors (at DISTRELEC for those who now this supplier) without built-in resistors so I thought it is a common thing (?).
    Hope this helps a little...
    Roger
  1. Help changing CCP3 output pin
    Last Post: - 15th July 2008, 02:30
  2. Bit Banging input to output on PIC16F876A
    By Bronurstomp in forum mel PIC BASIC Pro
    Last Post: - 26th June 2008, 19:50
  3. Serious Serial Situation Setbacks...
    Last Post: - 7th February 2007, 03:46
  4. Using LEDs as light sensors
    Last Post: - 30th December 2006, 22:19
  5. HSEROUT Newbie question/problem
    By Mark Scotford in forum mel PIC BASIC Pro
    Last Post: - 11th July 2006, 14:44
