Tristated output to two common Base transistor issue
Results 1 to 40 of 55
Threaded View
  1. #27
    Omaha, Nebraska USA
    Lightbulb
    Saturation is not possible, here are the results
    Thanks for showing us an in situ analysis. Your measurements should enable you to immediately infer what is wrong:
    The circuit, as configured, doesn't permit enough voltage across the transistor! (What is Vf for the LEDs?)
    If you remove the 22 ohm resistor to ground, you will get different results.
    Russ
    N0EVC, xWB6ONT, xWN6ONT
    "Easy to use" is easy to say.
  1. Help changing CCP3 output pin
    Last Post: - 15th July 2008, 03:30
  2. Bit Banging input to output on PIC16F876A
    By Bronurstomp in forum mel PIC BASIC Pro
    Last Post: - 26th June 2008, 20:50
  3. Serious Serial Situation Setbacks...
  4. Using LEDs as light sensors
    Last Post: - 30th December 2006, 23:19
  5. HSEROUT Newbie question/problem
    By Mark Scotford in forum mel PIC BASIC Pro
    Last Post: - 11th July 2006, 15:44
