Tristated output to two common Base transistor issue
Results 1 to 40 of 55
Threaded View
  1. #21
    Omaha, Nebraska USA
    Red face Mea culpa!
    BrianT advised me by private message that I had oversimplified my earlier analysis, and he is right. I looked only at the voltage divider created by the resisitors built into the transistors and neglected to consider the diode drop across the base-emitter junctions of the transistors. The circuit, redrawn, looks like this:
    <IMG SRC="http://www.picbasic.co.uk/forum/attachment.php?attachmentid=1980&stc=1&d=118913663 8">
    With the diode junctions in place (a nominal 0.7 VDC drop across each), two voltages change: At A, 4.3 volts; at C, 0.7 volt. At B, it remains 2.5 volts. Both transistors are still "turned on" if there is no voltage present (a high-impedance state) at B.
    Russ
    N0EVC, xWB6ONT, xWN6ONT
    "Easy to use" is easy to say.
  1. Help changing CCP3 output pin
    Last Post: - 15th July 2008, 02:30
  2. Bit Banging input to output on PIC16F876A
    By Bronurstomp in forum mel PIC BASIC Pro
    Last Post: - 26th June 2008, 19:50
  3. Serious Serial Situation Setbacks...
    Last Post: - 7th February 2007, 03:46
  4. Using LEDs as light sensors
    Last Post: - 30th December 2006, 22:19
  5. HSEROUT Newbie question/problem
    By Mark Scotford in forum mel PIC BASIC Pro
    Last Post: - 11th July 2006, 14:44
