Have you seen this? Post #3
http://www.picbasic.co.uk/forum/show...=multiple+pics
Thanks Dave, I searched the forums but must have used the wrong nomenclature, as usual. THANKS AGAIN
SOMRU
Thanks !
SOMRU
TWE/TFP/EE
Just happened to remember reading it when it was live.
Greeting all, been busy.
I have connected a 16f871 clko to a 16f870 clki, all seemed well.
Connected the 870 clko to a 16f818 clki, as per:
Method 2.
Connect OSC2 from the PIC1 with the Crystal, to OSC1 of PIC2 without. PIC2's OSC2 connects to PIC3's OSC1. PIC3's OSC2 connects to PIC4's OSC1... ad infinitum... Disadvantage: If one of the PICs failed, all the PICs down the chain from that PIC will cease operating also.
Results not so good. The 818 is not running, and have two more pics to drive.
O-scope shows a dc offset and diminishing low side, as it goes down the line.
Has anyone any ideas???
Thanks !
SOMRU
TWE/TFP/EE
Ensure you have HS Oscillator set in Config Fuses of all your PICs - this increases the drive levels and also allows you fan-out to more than one PIC down the line.
Good morning,
Yes all pics are set to HS, double checked I/O's.
Oscillators defined at 20 MHz.
I will check board for ground leakage on that net.
Thanks for the quick response.
This forum is BRILLIANT!!
Thanks !
SOMRU
TWE/TFP/EE
Good Afternoon,
Rerouted clock signal in several different configurations, serial/parallel and can still only get 3 of the five to roll. Am able to swap the last three around on end of run, same-same diag program and I/O, same results.
Went as far to hard wire the clock signals off board to eliminate stray capacitances.
Well.....
Back to the bench.
Should the the clock signal have the same voltage all the way down the line?? I would think so.
Going to replace crystal, caps, and main pic next.
Close but not quite ready for the BFH.
Thanks !
SOMRU
TWE/TFP/EE
