System Wide Clock?
Results 1 to 11 of 11
    Dec 2006
    WADSWORTH OHIO USA
    Red face System Wide Clock?
    Hello everyone, I currently have a design using 7 16F pics each performing time specific tasks.
    All pics are running at 20MHz. The question is would it be to any advantage to sync all the processors from a single clock source? If so, does anyone have any recommendations on a clock driver/distributor.
    SOMRU
    Thanks !
    SOMRU
    TWE/TFP/EE
    Dec 2006
    WADSWORTH OHIO USA
    Smile Many Thanks
    Thanks Dave, I searched the forums but must have used the wrong nomenclature, as usual. THANKS AGAIN
    SOMRU
    Thanks !
    SOMRU
    TWE/TFP/EE
    Just happened to remember reading it when it was live.
    Dec 2006
    WADSWORTH OHIO USA
    Unhappy Dwindling Clock
    Greeting all, been busy.
    I have connected a 16f871 clko to a 16f870 clki, all seemed well.
    Connected the 870 clko to a 16f818 clki, as per:
    Method 2.
    Connect OSC2 from the PIC1 with the Crystal, to OSC1 of PIC2 without. PIC2's OSC2 connects to PIC3's OSC1. PIC3's OSC2 connects to PIC4's OSC1... ad infinitum... Disadvantage: If one of the PICs failed, all the PICs down the chain from that PIC will cease operating also.
    Results not so good. The 818 is not running, and have two more pics to drive.
    O-scope shows a dc offset and diminishing low side, as it goes down the line.
    Has anyone any ideas???
    Thanks !
    SOMRU
    TWE/TFP/EE
    Ensure you have HS Oscillator set in Config Fuses of all your PICs - this increases the drive levels and also allows you fan-out to more than one PIC down the line.
  1. 32 bit square root
    Last Post: - 6th May 2009, 04:37
  2. EM4095 Chip, get Clock and Data signals?
    By mindthomas in forum mel PIC BASIC Pro
    Last Post: - 19th August 2008, 07:27
  3. Shiftout/in
    By BobEdge in forum mel PIC BASIC Pro
    Last Post: - 23rd August 2007, 12:48
  4. Help with sound command in 2 programs
    Last Post: - 5th July 2007, 21:36
  5. PIC16F877A - Timer0 won't interrupt
    By WishMaster^ in forum mel PIC BASIC Pro
    Last Post: - 25th April 2007, 09:25
