RF and PIC basic
Results 1 to 14 of 14
    Jun 2007
    Default RF and PIC basic
    Hello dear friends.
    I want to make a new project but, have some unknown.
    I have a transmitter module 433,92 Mhz rf module and PT2262 encoder I send any data and adress word. than I want to use rf receiwer modules 433,92 and PIC16F628 for decoding.
    So how can I read from PT2262 IC's datas whith PIC16F628
    Thanks for all
    If you use an ENCODER you will need a DECODER. (normally)
    Jun 2007
    yes it is true ..and I know. but I dont want to use any decoder Ic. because my project is working with PIC16F628 . so I want to write decoder code in my PIC16F628.
    thanks.
    I do not remember exactly, but I think dhouston or Bruce had a way to do this. Might have been for a Holtec Encoder though.
    Found it.
    http://www.picbasic.co.uk/forum/show...hlight=decoder
    Dec 2005
    The datasheet for the PT2262 doesn't provide any description of the communication protocol so, for starters, you will need to capture a few (different) codes and analyze them. This page shows how. http://davehouston.net/learn.htm
    Dec 2005
    I found another datasheet that does describe the protocol used by this chip. While the specifics for a "1", "0", and "F" differ from Holtek, the overall approach is very similar to the HT640. A bit period depends on the encoder oscillator frequency (set by an external resistor) you still need to capture some codes to determine the bit period. And there are some encoder pins that can be used either in the address or in the data so you'll need to determine that, also. Then you should be able to adapt Bruce's HT640 code to work with the PT2260.
    Nov 2009
    London
    Default Re: RF and PIC basic
    Any ideas (Bruce's code for HT640) if this will work if HT640 is used with other RF modules, like the normal el chipo style?
    I will give it a go to decode PT2262 soon.
    I tried to decode a UM3750/MM53200/HT12 type encoder with this either as subroutine or as Interrupt Driven Routine:
    GET_CODE:
        PULSIN DIN,0,NUMS
        IF NUMS > 8200 and NUMS<12000 then        'Detect Header
            goto get_pulses
    get_pulses:
          FOR X = 0 TO 11           ' read 12 pulses
            PULSIN DIN,1,NUMS        '
            if NUMS>220 then
                if NUMS<300 then
                    code.0[x]=1
            if NUMS>450 then
                if NUMS<560 then
                    code.0[x]=0
            if NUMS=0 then
                loops=0:code=0:flag=0
                RETURN    '   temp=0:
       next x
       if loops<3 then
        if prev_code=code then
            loops=loops+1
            prev_code=code
            loops=0
    But I got a delay in decoding. It just gets one every 4 transmissions. So for a 4 times check of equall transmitted codes, it takes more than 250ms to give a valid. With the Logic Digital Analyser it is confirmed that it takes 1st transmission, then 4th etc.
    The numbers in NUM are PIC and OSC clock dependant.
    If anyone can spot why, please reply.
    What var size is NUM?
    Word sized.
    It does work but gets one every 4th. Very strange...
    I have not here the Logic. In the afternoon I will post a shot of the pulses to make it more clear.
    The posted routine was tested also as part of Darrels DT-INTs on a fast 16F1827 chip at 32MHz clock.
    Bombay, India
    Ioannis, not sure what you mean by gets one every 4th. The way I understand your statement is that you get a valid pulse once in 4 transmissions. If that is correct, the code which does that is the loops part. if loops < 3 then ..... When it finds a code 'repeated' 4 times, it transfers to the Prev_code. Is that what you're looking for??
    Hi Jerson. No, it is not that the case. It just gets the first train of pulses but not the second one after the header of 11ms. It waits for a reason that I do not understand and gets the 4th train again. I try to get a shot from the Logic screen and post it next.
    Here is the picture:
    The first channel shows the data received from the Rx module.
    The second shows every time the routine detects the header like this:
     PULSIN DIN,0,NUMS
            toggle portb.4
            goto get_pulses
            'goto get_p
    That delay is constant and not random. So it must be either a shortage ofthe lanquage or my mistake (possibly).
    Cambridge UK
    I know this is an old thread, I am trying to decode a PT2262 encoder using a PIC could do with someone looking at my code to see where I am going wrong. The code is modified from Bruce's Holtec decoding routine.
    I can read the buttons pressed using the code below, but it only works if I hold the Tx a few inches from the Rx. I think there is a timing problem.
    I have measured the waveforms at the output of the encoder and they are;
    120uS for a logic 0 and 400uS for a logic 1 with a duty cycle of 500uS. Each pulse train is spaced at 4mS, each button press is repeated 4 times. See the data sheet posted in dhoustons link above.
    I am using the bit24 (sync) as the reference bit as its the only constant in the pulse train.
    Thanks Nick
    @ __config _INTRC_OSC_NOCLKOUT & _WDT_ON & _PWRTE_OFF & _MCLRE_OFF & _BOD_OFF & _CP_ON & _CPD_ON
    OSCCON  = %01110000     ' Internal 8MHz osc
    ANSEL = %00000000
    CMCON0 = 7
    Define OSC 8                ' Define oscilator speed
    DEFINE DEBUG_REG GPIO
    DEFINE DEBUG_BIT 0 				'GPIO.0
    DEFINE DEBUG_MODE 0 			'Inverted
    DEFINE DEBUG_BAUD 9600          'Baud rate to LCD
    define DEBUG_PACING 1000
    DEFINE PULSIN_MAX 3000  ' Set MAX wait period
    INCLUDE "modedefs.bas"
    GPIO=0                 ' All outputs = 0 on boot
    GPIO=%00100000         ' GPIO.5 = in, rest outputs.
    PBIT        VAR BYTE[24]' Pulse-in results of high-going address/data/ synch
    NUMS        VAR WORD    ' Pulsin result of low-going synch period
    ADDRESS     VAR Byte    ' Holds decoded 8-bit address
    ADDRESS2    VAR Byte    ' 2nd address storage for verification pass
    ADDRESS3    VAR BYTE    ' 3rd address storage for verification pass
    DBYTE       VAR BYTE    ' Holds decoded 8-bit data byte
    DBYTE2      VAR BYTE    ' 2nd data byte storage for verification pass
    DBYTE3      VAR BYTE    ' 3rd data byte storage for verification pass
    X           VAR BYTE    ' GP loop counter/array index pointer
    Y           VAR BYTE    ' Address & Data bit index pointer
    Z           var byte    ' Used to display button press
    LOOPS       VAR BYTE    ' Loop counter for address & data match
    P_MAX       VAR BYTE    ' Wide pulse (indicates GND)
    P_MIN       VAR BYTE    ' Narrow pulse (indicates Vcc)
    DIN         VAR GPIO.5  ' Data input pin from RF receiver
    LED         VAR GPIO.2  ' Visual cue
    High LED
    pause 2000
    Debug $FE,1,"Power UP"   'Output received data to the world
    Debug $FE,1,"Waiting for"   'Output received data to the world
    Debug $FE,$C0,"Button press"
    Begin:                  ' Clear vars on power up & start over.
        ADDRESS=0 : ADDRESS2=0 : ADDRESS3=0 : DBYTE=0 : DBYTE2=0 : DBYTE3=0 : LOOPS=0
    GET_P:
        'PULSIN DIN,0,NUMS   ' Get low going synch period pulse.
        'IF NUMS = 0 THEN    ' If NUMS=0, no synch pulse within defined period.
        ' Loops=0            ' Clear "1st pass" address & data loop counter.
        ' GOTO GET_P         ' Keep looking.
       ' ENDIF
        ' Normally the synch pulse is between 11-16mS, so we'll reject any synch pulse < 10mS
        ' to allow for variations in timing & transmitter voltages.
        'IF NUMS < 1000 THEN GET_P ' 1000 X 10uS = 10mS (PULSIN = 10uS resolution at 4MHz)
        FOR X = 0 TO 24        ' 25 bits in total for pt2262
         PULSIN DIN,1,NUMS     '
         IF NUMS < 20 THEN GET_P 'USED TO REJECT NOISE
         PBIT[X] = NCD NUMS    ' 25 bits total. 1 synch, 16 address, 8 data
        NEXT X                 ' Note that the PT2262 uses two pulses form each bit.
        ' Now load P_MAX & P_MIN for sort loops below to sort out
        ' address/data bit logic states.
        P_MAX = PBIT[0] ' Not used yet
        P_MIN = PBIT[24] ' "narrow" synch bit
        ' Decode 8-bit address
        ADDRESS = $FF  ' Start with all 1's & find each zero bit
        Y=0             ' Zero address bit index pointer
        ' PBIT[0] + PBIT[1]=1st address bit. PBIT[14] + PBIT[15]=last
        FOR X = 0 to 15  STEP 2 ' Increment x 2 each pass
          IF (PBIT[X] = P_MIN) AND (PBIT[X+1] = P_MIN) THEN
             ADDRESS.0[Y]=0
          Y=Y+1   ' Increment address bit index pointer
        NEXT X
        ' Decode 8-bit data byte (decode button press)
        DBYTE = $FF  ' Start with all 1's & find each zero bit
        Y=0          ' Zero data bit index pointer
        ' PBIT[16] + PBIT[17]=1st data bit. PBIT[22] + PBIT[23]=last
        FOR X = 16 TO 23 STEP 2 ' Increment x 2 each pass
          IF PBIT[X] AND PBIT[X+1] = P_MIN THEN DBYTE.0[Y]=0
          Y=Y+1   ' Increment data bit index pointer
        NEXT X
        ' On 1st pass, load 1st address & data into verify registers,
        ' then return for 2nd pass at pulsin. We'll make address &
        ' data match twice before moving on.
        Loops = Loops + 1   ' Increment loop counter
        'if LOOPS = 1 THEN GET_P
        IF Loops = 1 THEN   ' 2nd pass through?
         Address2 = Address ' Yes. Load 1st address into match register
         DBYTE2 = DBYTE     ' Load 1st data into match register
         GOTO GET_P         ' Get 2nd readings for comparison with 1st two
        ' 2nd pass, so verify address & data bytes.
        ' If they match, show button press
    CONTINUE:
        IF (DBYTE = DBYTE2) AND (ADDRESS = ADDRESS2) THEN  ' Show only if both data bytes equal
            if DBYTE2 = %11110001 THEN Z = "B"
            if DBYTE2 = %11111000 THEN Z = "A"
            if DBYTE2 = %11110010 THEN Z = "D"
            if DBYTE2 = %11110100 THEN Z = "C"
            Debug $FE,1,"Add=",$14,#address2   'Output received data to the world
            Debug $FE,$C0,"Button=",$14,z
        GOTO Begin  ' Start over.
    Sep 2013
    Hi Agent36,
    Have you had a chance to get an answer to your issue mentioned in your last message?. I am going to start a project to decode PT2260. So I wanted to be sure that the code works without an issue. You mentioned that code works if the distance is so close (a few inches).
    Best regards
    Koray
  1. mrf24j40 RF transciever with pic
    Last Post: - 17th September 2008, 15:11
  2. RF transmiter reciever using PIC
    By drama in forum mel PIC BASIC
    Last Post: - 4th October 2007, 16:26
  3. PIC 12F675 RF use
    By cooksydesign in forum mel PIC BASIC Pro
    Last Post: - 2nd September 2006, 15:06
  4. Generating RF from a PIC
    By Rob Martin in forum mel PIC BASIC Pro
    Last Post: - 26th January 2006, 20:26
  5. LINX RF module and PIC (#2)
    By Michael in forum mel PIC BASIC Pro
    Last Post: - 22nd January 2006, 17:56
