RF and PIC basic
Results 1 to 14 of 14
    Jun 2007
    Default RF and PIC basic
    Hello dear friends.
    I want to make a new project but, have some unknown.
    I have a transmitter module 433,92 Mhz rf module and PT2262 encoder I send any data and adress word. than I want to use rf receiwer modules 433,92 and PIC16F628 for decoding.
    So how can I read from PT2262 IC's datas whith PIC16F628
    Thanks for all
    If you use an ENCODER you will need a DECODER. (normally)
    Jun 2007
    yes it is true ..and I know. but I dont want to use any decoder Ic. because my project is working with PIC16F628 . so I want to write decoder code in my PIC16F628.
    thanks.
    I do not remember exactly, but I think dhouston or Bruce had a way to do this. Might have been for a Holtec Encoder though.
    Found it.
    http://www.picbasic.co.uk/forum/show...hlight=decoder
    Dec 2005
    The datasheet for the PT2262 doesn't provide any description of the communication protocol so, for starters, you will need to capture a few (different) codes and analyze them. This page shows how. http://davehouston.net/learn.htm
    Dec 2005
    I found another datasheet that does describe the protocol used by this chip. While the specifics for a "1", "0", and "F" differ from Holtek, the overall approach is very similar to the HT640. A bit period depends on the encoder oscillator frequency (set by an external resistor) you still need to capture some codes to determine the bit period. And there are some encoder pins that can be used either in the address or in the data so you'll need to determine that, also. Then you should be able to adapt Bruce's HT640 code to work with the PT2260.
  1. mrf24j40 RF transciever with pic
    Last Post: - 17th September 2008, 16:11
  2. RF transmiter reciever using PIC
    By drama in forum mel PIC BASIC
    Last Post: - 4th October 2007, 17:26
  3. PIC 12F675 RF use
    By cooksydesign in forum mel PIC BASIC Pro
    Last Post: - 2nd September 2006, 16:06
  4. Generating RF from a PIC
    By Rob Martin in forum mel PIC BASIC Pro
    Last Post: - 26th January 2006, 21:26
  5. LINX RF module and PIC (#2)
    By Michael in forum mel PIC BASIC Pro
    Last Post: - 22nd January 2006, 18:56
