SERIN2 – SEROUT2 and Manchester mistake.
Results 1 to 9 of 9
    Jan 2006
    North of France
    Question SERIN2 – SEROUT2 and Manchester mistake.
    Hello, i'm trying to send some datas over wireless network from a pic to another one.
    For the explanation, pic sender is PICTX and the other is PICRX.
    My pics are 12F683 both.
    The code sent by the PICTX seems to be okay
    Example : If PICTX send the letter " d " in Manchester style over the 433Mhz network, i can read 01 10 10 01 01 10 01 01 on the input pin of PICRX.
    Okay but not perfect because i haven't work enough to send the WakeUp string in Manchester style….
    This is the code i use for the PICTX :
    '---------- Begining
    @ device PIC12F683, intrc_osc_noclkout, wdt_off, pwrt_on, mclr_off, protect_off, bod_on
    OSCCON = %01110000
    DEFINE OSC 8
    ansel = 0
    cmcon0 = 7
    trisio = %000011
    INCLUDE "modedefs.bas"
    SYMBOL TRANSMISSION = GPIO.2
    DEFINE CHAR_PACING 100
    LOW TRANSMISSION
    Clear
    Pause 200
    '---------- End of header and now here are the variables
    CounterA var Byte
    MyDataIn var Byte
    ManchesterWord var Word[6]
    '---------- End of variables and now, here is the heart
    MyDataIn = "d"
    GOSUB EncodeManchester
    serout2 TRANSMISSION, 16468, [$55,$55,$55,$aa,IBIN16 Manchesterword,13,10]
    '----------Manchester Encoding
    EncodeManchester:
    ManchesterWord=0
    For CounterA=0 to 7
    If MyDataIn.0=0 then
    ManchesterWord.14=1
    ManchesterWord.15=1
    If CounterA<7 then ManchesterWord=ManchesterWord>>2
    MyDataIn=MyDataIn>>1
    Next CounterA
    'EOF
    Well, now, let's talk about my PICRX.
    I did a mistake into my code but i don't find wich...
    I'm not able to decode my manchester words.
    This is the code i use for PICRX:
    @ device PIC12F683, intrc_osc_noclkout, wdt_off, pwrt_off, mclr_off, protect_off, bod_on
    OSCCON = %01110000
    DEFINE OSC 8
    ansel = 0
    cmcon0 = 7
    trisio = %001000 ' Input pin is GPIO 3
    LED VAR GPIO.0
    RECEPTION VAR GPIO.3
    INFO VAR GPIO.2
    CounterA var Byte
    ErrorFlag var Bit
    WakeUp var Byte
    MyDataOut var Byte
    ManchesterWord var WORD[6]
    Clear
    Low LED
    LOW INFO
    FLAG = 1
    Pause 1000
    Wait55:
    SERIN RECEPTION, n9600, WakeUp
    If WakeUp = $55 Then
    If WakeUp = $aa Then
    goto Receive
    Goto Wait55
    Receive:
    SERIN2 RECEPTION, 16468, [ManchesterWord] ' MY ERROR IS HERE I THINK!!
    serout2 INFO, 16468, ["This is ManchesterWord : ",IBIN16 ManchesterWord,13,10]
    GOSUB DecodeManchester
    IF ERRORFLAG THEN
    serout INFO, N9600, ["Error !",13,10]
    Pause 300
    goto Wait55
    serout INFO, N9600, ["Value is Okay. (",MyDataOut,")",13,10]
    GOSUB Action
    GOTO Wait55
    Action :
    If (MyDataOut = "c") Then
    High LED
    Pause 1000
    Low Led
    Endif
    DecodeManchester:
    ErrorFlag=0
    For CounterA=0 to 7
    If ManchesterWord.1=0 then
    MyDataOut.7=0
    If ManchesterWord.0=0 then ErrorFlag=1
    MyDataOut.7=1
    If ManchesterWord.0=1 then ErrorFlag=1
    If CounterA<7 then MyDataOut=MyDataOut>>1
    Next CounterA
    'EOF
    I’m sure it’s a stupid error but i’ve tried many things and i didn’t found.
    Any help ?
    Thanx a lot.
    Lyd.
    I looked at you code and see that you are using the internal OSC, I would not spend much time de-bugging until these are changed to externals.
    99.99% of the time internal OSC are not reliable enough for serial com.
    Go with a "resonator" the kind with three pins, and built in caps.
    Jan 2006
    North of France
    Thanx mackrackit i know what you say but my problem is not here because, if i don't use the Manchester Encoding/Decoding, it work like a charm, event at 9.6Kbps (i'm glad to saw that).
    When i transmit in "clear mode" everything is good.
    My error is here :
    Because ManchesterWord is double sized than normal byte.
    I've tried with SERIN2 RECEPTION, 16468, [STR...
    but it's impossible because ManchesterWord is "VAR WORD".
    Because i'm just beginner with serin / serout, i don't know all the tips and there is probably one wich can do the rest.
    (and sorry for my bad English language, mine is French)
    Lyd.
    This is my best guess, but I am not sure as I do not see anything else.
    Where you have IBIN16 , try not using the I. This adds an extra character to the 16 digit string. Worth a quick try?
    Perth, Australia
    This should do it:
    SERIN2 RECEPTION, 16468, [ManchesterWord.Byte0,ManchesterWord.Byte1]
    Jan 2006
    North of France
    Quote Originally Posted by Kamikaze47 View Post
    This should do it:
    Yes, it' s the same code as bruce just posted too.
    I just need to modify my serout on TXPIC too.
    Nice to saw all your replies.
    Lyd.
    IBIN16 is sending % followed by 16 bytes of data. Not just 16-bits. This produces an
    ASCII 0 or 1 for each bit in the word.
    Try something like;
    serout2 TRANSMISSION,16468,[$55,$55,$55,$aa,Manchesterword.LowByte,Manchesterword.HighByte]
    On the receiving end, try something like;
    SERIN2 RECEPTION, 16468, [WAIT($aa),ManchesterWord.LowByte,ManchesterWord.HighByte]
    This way SERIN2 on the receiving end simply ignores your $55 and waits for $aa before the
    16-bit data packet.
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    Jan 2006
    North of France
    Try something like .../...
    Well, it's fantastic, you just turned my simple remote to remote-control ;O)
    Yes, your solution works fine.
    Many thanx all for your fast replies.
    Lyd.
    Jan 2006
    North of France
    Well i've just done a test :
    This is what i send: 0110100101100101
    This is what i get on the RXPIC input pin named RECEPTION and connected to the RF 433Mhz circuit: 0110100101100101
    You can see it's the same datas.
    Now, if i do
    SEROUT2 INFO, 16468, [BIN16 ManchesterWord,13,10]
    This is what i get on the RXPIC pin named INFO : 0000000000100101
    So my error is a pure coding mistake, not RF.
    Thanx for you help.
  1. Reading in Manchester code
    By brid0030 in forum Code Examples
    Last Post: - 10th March 2009, 21:55
