LCD_AnyPin.pbp
+ Reply to Thread
Results 1 to 40 of 113
Thread: LCD_AnyPin.pbp
    Nov 2009
    In your code above, you have MCLRE enabled.
    But in the schematic you don't have a pull-up on MCLR (Pin 1).
    I'll try adding that, thank you. I'm sorry to keep bugging you about this.
    Just curious why you have LCD Data on RB2,3,4 & 5. If you simply moved them up two pins and moves E and RS down, you could use the standard PICBasic product with no modifications. I can understand if you have a PIC which doesn't have four consecutive pins available on a port, but why go to all the inconvenience when there is no need?
    The circuit board is an existing design, I'd love to move things but I have to go with the produced PCB. The next thing one might wonder is how a person like me ends up with this on his plate? well I have VB, C, C++, MFC and C# experience and someone, in their infinite wisdom thought I'd be good to take this on as a "challenge". What I have absolutely zero experience with is PIC microcontrollers which seems to be a long-shot away from Windows programming.
    I'm sorry if I'm testing anyone's patience over this, perhaps PBP isn't the right tool for this task, perhaps I'll look into some C implementations for achieving this task.
    Unless Darrel has done this routine in C, I think you won't find a solution in other places...
    Jan 2006
    Istanbul
    I touched nothing on your code.
    Just compiled it as is.
    And it works with no problem as seen in the simulation (attached).
    http://www.picbasic.co.uk/forum/atta...1&d=1259222341
    WooHoo!
    Now there's a $1000 simulation.
    Nov 2009
    Quote Originally Posted by sayzer View Post
    Actually I see you have a pull-up on pin 1 and also have pin 7 tied low.
    I don't see how pin 7 can be any problem for me but looking at the PCB I notice it doesn't have the pull-up on pin 1.
    Existing (pre-programmed) 16F883's I have on my bench are working fine when inserted into this PCB so I have reservations thinking that's the problem at hand.
    Thanks for your responses everyone.
    Apr 2006
    New Hampshire USA
    Post due diligence
    Quote Originally Posted by PICn-It View Post
    See Darrel's Question...
    Is the RW pin on the LCD connected to the PIC, or is it grounded?
    Nov 2009
    Quote Originally Posted by Pic_User View Post
    I'm sorry I don't understand your post, but I tried it with MCRLE_OFF and it makes no difference. I must have some other issues I'm yet unaware of. I have ordered a proper dev board so when that comes maybe I can get a handle on the problem.
    I had set MCRLE_ON from trying to interpret the data sheet:
    Page-212:
    MCLRE: RE3/MCLR pin function select bit(4)
    1 = RE3/MCLR pin function is MCLR
    0 = RE3/MCLR pin function is digital input, MCLR internally tied to VDD
    Page-215 (14.2.2)
    An internal MCLR option is enabled by clearing the
    MCLRE bit in the Configuration Word Register 1.
    When MCLRE = 0, the Reset signal to the chip is generated
    internally. When the MCLRE = 1, the RA3/MCLR pin
    becomes an external Reset input. In this mode, the
    RA3/MCLR pin has a weak pull-up to VDD.
    These data sheets are a long read and at times I'm having trouble interpreting some of the pages.
    Nov 2009
    Ok, making great progress.
    I recieved my development board, plugged everyting in and coded up the demo example again ....and I'm getting text!
    (woo-hoo!)
    I'm getting:
    #numbers Hello,
    $hex From DT!
    is this correct?
