LCD_AnyPin.pbp
+ Reply to Thread
Results 1 to 40 of 113
Thread: LCD_AnyPin.pbp
    Nov 2009
    Are you sure LCD is OK?
    Yes, when I plug it into another pic controlled unit I get both lines of verbiage expected.
    Is the RW pin on the LCD connected to the PIC, or is it grounded?
    The circuit board has the RW line hard-wired to ground.
    Would it be better to re-post this Q over in the regular part of the forum since it's doesn't seem related directly to the LCD_Anypin extension? my thinking is it might be something peculiar to the 16F883 that someone may see and chime-in about.
    Nov 2009
    Schematic attached.
    (Note that in the code I'm not doing anythng with the sensor yet, and it's disconected from AN0 right now)
    Nov 2009
    (sound of crickets chirping....)
    Just curious why you have LCD Data on RB2,3,4 & 5. If you simply moved them up two pins and moves E and RS down, you could use the standard PICBasic product with no modifications. I can understand if you have a PIC which doesn't have four consecutive pins available on a port, but why go to all the inconvenience when there is no need?
    In your code above, you have MCLRE enabled.
    But in the schematic you don't have a pull-up on MCLR (Pin 1).
    Nov 2009
    I'll try adding that, thank you. I'm sorry to keep bugging you about this.
    The circuit board is an existing design, I'd love to move things but I have to go with the produced PCB. The next thing one might wonder is how a person like me ends up with this on his plate? well I have VB, C, C++, MFC and C# experience and someone, in their infinite wisdom thought I'd be good to take this on as a "challenge". What I have absolutely zero experience with is PIC microcontrollers which seems to be a long-shot away from Windows programming.
    I'm sorry if I'm testing anyone's patience over this, perhaps PBP isn't the right tool for this task, perhaps I'll look into some C implementations for achieving this task.
    Unless Darrel has done this routine in C, I think you won't find a solution in other places...
