LCD_AnyPin.pbp
Results 1 to 40 of 113
Thread: LCD_AnyPin.pbp
Threaded View
  1. #17
    Nov 2009
    Darrel, so I cut-n-pasted your exact code into a new project, changed only the LCD VARs, and am now getting much farther than before...but...
    Now I'm getting stuck when LCD_Anypin.pbp compiles, the code is cut from your 1st post, my only change was:
    LCD_DB4   VAR PORTB.5
    LCD_DB5   VAR PORTB.4
    LCD_DB6   VAR PORTB.3
    LCD_DB7   VAR PORTB.2
    LCD_RS    VAR PORTB.7
    LCD_E     VAR PORTB.6
    and here is my latest spew:
    (MPLAB v8.4/PBP v2.6)
    Executing: "D:\PBP\PBPMPLAB.BAT" -ampasmwin -k# -p16F883 "Untitled.bas"
    Executing: "D:\PBP\PBPW.EXE" -ampasmwin -k# -p16F883 "Untitled.bas"
    PICBASIC PRO(TM) Compiler 2.60, (c) 1998, 2009 microEngineering Labs, Inc.
    All Rights Reserved.
    Pass 1:
    Pass 2:
    Code Gen:
    Macro Pass:
    mpasmwin /o- "D:\PIC Projects\Untitled.ASM"
    COFF Pass:
    Executing: "D:\PBP\PBPMPLAB.BAT" -ampasmwin -k# -p16F883 "D:\PBP\VirtualPort.bas"
    Executing: "D:\PBP\PBPW.EXE" -ampasmwin -k# -p16F883 "D:\PBP\VirtualPort.bas"
    Pass 1:
    Pass 2:
    Code Gen:
    Macro Pass:
    mpasmwin /o- D:\PBP\VirtualPort.ASM
    COFF Pass:
    Executing: "D:\PBP\PBPMPLAB.BAT" -ampasmwin -k# -p16F883 "D:\PBP\LCD_AnyPin.pbp"
    Executing: "D:\PBP\PBPW.EXE" -ampasmwin -k# -p16F883 "D:\PBP\LCD_AnyPin.pbp"
    Pass 1:
    D:\PBP\LCD_ANYPIN.PBP ERROR Line 87: Bad expression.
    Line 00087: LOW LCD_RS : HIGH LCD_E ; Start with RS LOW and Enable High
    Pass 2:
    Code Gen:
    Macro Pass:
    Halting build on first failure as requested.
    BUILD FAILED: Sat Nov 14 23:28:52 2009
    Is the error on line 87 something I've done/not-done?
Members who have read this thread : 11
