LCD_AnyPin.pbp - Page 3
+ Reply to Thread
Page 3 of 3 FirstFirst 123
Results 81 to 113 of 113
Thread: LCD_AnyPin.pbp
  1. #81
    Each family of PIC's has it's own library.
    PBPPIC14.lib is for the normal 14-bit cores (12, 16F).
    PBPPIC18.lib is for the 18F's.
    PBPPI18L.lib is for 18F's with PBPL (longs).
    And PBPPI14E.lib is the enhanced 14-bit cores.
    The HighJack routines should be installed in the corresponding .lib file for the PIC you want to use LCD_AnyPin with.
    Once again ... make a copy of the file before editing it !!!!
    Default fixed
    Thank You,
    I was changing the PBPPIC14.LIB instead of the PBPPI14E.LIB .... NOW IS FINE
    once again Thank You
  3. #83
    Default LCDOUT for other LCD controllers than HD44780
    Do you think is a way to use LCDOUT (using LCD_AnyPin) to a HD66717 lcd module considering the diferences from HD44780 ?
    HD44780 vs HD66717.pdf
  4. #84
    Yes.
    That should be easy to do.
    bogdan , It sound like 8 bit instead of 4 bit mode....
    Jan 2006
    Istanbul
    Default Re: LCD_AnyPin.pbp
    For PIC16F737, I am getting "ERROR: (HighJacked-LCDOUT Not found in PBPPIC??.LIB"
    The HighJack routine is in all the files needed.
    What am I missing?
    Thank you.
  7. #87
    Do you have more than 1 installation of PBP?
    MCS or MPLAB may be looking at a different folder.
    Or the routines may be inserted in the wrong lines of the .lib file.
    Jan 2006
    Istanbul
    Hi Darrel,
    It is compiling it for other PICs with no problem.
    And checking the lines of the files for inserted codes, they are all ok.
  9. #89
    The library file used with the PIC16F737 is PBPPIC14.lib
    If it compiles for other 16F's like an 877a then I don't see a reason for it to not compile for the 737.
    Do you have any LCDOUT commads in your program? Or are you trying to compile the include by itself?
    If there are no LCDOUT statements, the HighJack routines will not be included.
    Jan 2006
    Istanbul
    There is the issue.
    In fact, it was among my notes, but I missed it.
    Problem solved.
    Thank you Darrel.
  11. #91
    Feb 2011
    Is it possible to take this 1 step further and support LCDs with 2 Enable pins?
  12. #92
    Yes, we've done that.
    If you don't need to scatter the data bus pins, you can do it with this ...
    http://www.picbasic.co.uk/forum/show...=2388#post2388
    Or if the data bus need to be scattered, there's this thread ...
    In particular post #35, but read the whole thread.
    http://www.picbasic.co.uk/forum/showthread.php?t=7596
    Jul 2011
    I have try with succes the library but I have a strange error. I have compiled this simple part of code:
    LCD_DB4         var PORTB.1
    LCD_DB5         vAR PORTB.2
    LCD_DB6         VAR PORTB.3
    LCD_DB7         VAR PORTB.4
    LCD_RS          VAR PORTB.5
    LCD_E           VAR PORTC.5
    LCD_LINES       CON 1
    LCD_DATAUS      CON 50
    LCD_COMMANDUS   CON 1500
    OSC             con 20
    TRISA.0 = 1
    TRISB = 0
    TRISC = 0
    INCLUDE "LCD_AnyPin.pbp"
    lcdout $FE,1
    pause 250
        lcdout $FE, $80, "Abcdef"
    Ever:
        high PORTA.1
        PAUSE 500
        LOW PORTA.1
        PAUSE 500
    GOTO Ever
    When I run this I see odd things like "AAdfg" or " dAfg" etc etc. I think that is a timing error, you have suggestion for this kind of error?
    Thank you (and sorry for my bad english).
  14. #94
    Jan 2006
    Istanbul
    What is this "OSC con 20" doing in there?
  15. #95
    Also use these:
    DEFINE LCD_COMMANDUS 2000
    DEFINE LCD_DATAUS 100
    NOT these:
    LCD_DATAUS      CON 50
    It should be the constants, not the defines.
    But Sayzer is right. OSC con 20 will not compile if you have used DEFINE OSC 20.
    Which means PBP thinks your PIC is running at 4Mhz.
    Jul 2011
    Sorry you guys, I wrote:
    OSC WITH 20
    but I had to write:
    DEFINE OSC 20
    I could not understand the error because it compiled correctly. Thanks to all.
  18. #98
    Mar 2009
    Colorado
    Was LCD_AnyPin included in PBP version 2.6 as was suggested a couple of times in this thread? If not, why not?
  19. #99
    Mar 2009
    Colorado
    Now that PBP3 is released let me re-phrase my above question: Was LCD_AnyPin included in PBP3 and if not, why not?
  20. #100
    Not it's not, because it's not a common and frequent way to use an LCD.
  21. #101
    The mechanism used in LCD_ANYPIN that overrides library commands was used in PBP3.
    However, it was used in the HPWM command due to necessity.
    Microchip changed the 18FxxK80 parts so much that the CCP modules were not compatible with the old HPWM library code.
    So Jeff wrote some new HPWM routines, I came up with a way to replace the existing library routines (borrowing from LCD_AnyPin), then Charles did the actual implementation on a chip by chip basis in the .pbpinc files. Really cool stuff.
    We've talked about it alot, and as long as no bad side affects are found with the K80 HPWM commands ... one possibility is to allow overriding many of the library functions with new routines, and I'm sure LCD_AnyPin will be one of the first if that happens.
    Steve,
    In another thread you mentioned PBP_HARDWAREDEF.
    That's part of the library override.
    In the .pbpinc file for a K80, that macro is declared.
    It is simply a #include, that adds the new code for HPWM.
    A #define is added too (HPWM_OVERRIDE).
    The old library code is wrapped with IFNDEF HPWM_OVERRIDE, so with the define ... the old routines are eliminated and the new included routines take over.
    Imagine overriding HSERIN/HSEROUT to use buffers.
    Thanks for the explanation, still waiting the user command (whatsoever it is called) explanation
    I can imagine a load of override AND overload without any problem...I also have no problem to imagine why people think we are so excited about that. And, finally, I have no problem to imagine how many rants & questions this will bring as well... maybe we can finally get rid of those "WHY my LED do not blink on PORTA" questions?
  23. #103
    ;  Additional header code to accommodate device-specific library routines
    #header
        #define HPWM_OVERRIDE 1
    PBP_HARDWAREDEF  macro
        #include PBP_PATH\HPWM_K80_1.HWLIB
    #endheader
    Hhhhhhhhhhha! Another thing to chew on... even if it's just fow HPWM now....
    HPWM "Hello", 13,10
  24. #104
    Feb 2005
    Kolkata-India
    Another weird proposition.
    LCDOUT is a blocking command if I am not wrong and it would be great if a task/que scheduler like app could be designed. During command delay it wastes 2 ms. I believe a whole LCD update/refresh within 200ms should be acceptable.
    So the idea is keeping a buffer equal to the total number of LCD character and updating the LCD from it character by character at 2ms interval, through an ISR. So a LCDOUT $FE, 1 just clears the buffer and LCDOUT puts the character in buffer rather than sending it directly to LCD I/Os. Making the timebase 1ms maybe through a compare module may couple other functions as well. RTC for example, non-blocking interrupt compatible delays, MUX options on the LCD lines etc. Use of 2 dimensional arrays makes it possible to have different LCD display screens ready to called just by a pointer may be automatically, sequentially, unattended.....
    Hey I am not drunk ........I did it a couple of years back in a hard way. LCD being handled entirely in ASM and not compatible with LCDOUT.
    Can't afford 2ms delays in my sinewave inverter (Work in Progress for a PBP WiKi)
    Sougata
  25. #105
    Dec 2011
    IO93ok
    I'm trying to use LCD_Anypin with an external clock but I'm not having success. Pic 16f819 (Posted in another thread in PBP Pro)
    I wrote some code incorporating LCD_Anypin and ran it on a development board with a 10Mhz crystal oscillator. I used one odd pin for the LCD.
    It compiled with DEFINE OSC 10 and it ran perfectly on the development board.
    I then placed the chip into a working board using an external 10Mhz clock input and set the fuses accordingly. This was the only change in hardware.
    Software wise I tried DEFINE EXTCLK_OSC and the same plus 10 on end, I also tried OSC 10 as well. Both these produced an output on the LCD but very oddly.
    4 line display. As a test I did LCDOUT $FE,$80,"TEST" and LCDOUT $FE,$94,"AAAA"
    resulted in:-
    1st Line has a flashing cursor at the end of the line.
    2nd line blank
    3rd line has ooo<
    4th line blank
    Adding charactrs to the LCDOUT matches character count on 3rd line. i.e AAAAAA produces ooooo<
    I wondered if there was something specific timing wise that LCD_Anypin wouldn't work correctly with an external clock?
    Anyone any ideas why I get the gobbledegook output with ext clk and correct text with xtal input??
  26. #106
    Jan 2006
    North of France
    Hello.
    Old thread but so useful !
    Thanx to Darrel.
    Fyi this mod seems not working with SPLC780D / 4 lines / 20char.
    It compiles but the screen show various contrasts.
    I'll try with a HD44780 next week and will confirm.
  27. #107
    Jan 2006
    North of France
    Question Re: LCD_AnyPin.pbp
    I'checked today and did a try vith an LCD 2 lines and same issue.
    Then I suppose the problem doesnt come from the screen.
    PIC : 16F685
    PBP : 2.60C
    Modded files : pbppic14.lib pbppi14e.lib pbppic18.lib pbppi18l.lib
    Added files in PBP dir : LCD_AnyPin.pbp & VirtualPort.bas
    Shematic is exactly identical in case one and 2.
    Case one - The code below works with modded files but without use AnyPin function :
    @ device PIC16F685, intrc_osc_NOCLKOUT, wdt_off, pwrt_on, mclr_off, protect_off, bod_on
    ANSEL  = %00000000       ' Set pin AN0 to AN7
    ANSELH = %0000           ' Set pins AN8 to AN11
    Define LCD_COMMANDUS 2000 ' Command Delay (uS)
    Define LCD_DATAUS 50 ' Data Delay (uS)
    DEFINE LCD_DREG PORTB               ' Set LCD Data on PORTB
    DEFINE LCD_DBIT 4                   ' Set starting Data bit on PORTB.4 (0 or 4) if 4-bit bus i.e, PortB.4-PORTB.7
    DEFINE LCD_RSREG PORTC              ' Set LCD Register Select on PORTA
    DEFINE LCD_RSBIT 6                  ' Set LCD Register Select bit on PORTA.4 (PORTA.3 is only in input mode)
    DEFINE LCD_EREG PORTC               ' Set LCD Enable on PORTC
    DEFINE LCD_EBIT 7                   ' Set LCD Enable bit on PORTC.7
    DEFINE LCD_BITS 4                   ' LCD in 4 bit mode
    DEFINE LCD_LINES 2                  ' 4 lines LCD display
    ;----[ Your Main program starts here ]----------------------------------------
    LoopCount VAR WORD
    PAUSE 500 : LCDOUT $FE,1 : PAUSE 250 ; Initialize LCD (You may not need this,
                                         ; but some displays are picky)
        LCDOUT $FE,1 ; clear screen
        PAUSE 1000
        LCDOUT $FE,"Starting..."
        PAUSE 1000
        LCDOUT $FE,$87,"Hello,",$FE,$C8,"From DT!"
        FOR LoopCount = 0 TO 65535
            LCDOUT $FE,$80, IDEC LoopCount
            LCDOUT $FE,$C0, IHEX4 LoopCount
        NEXT LoopCount
    GOTO Main
    Case two - The code below doesnt work with modded files and using AnyPin function :
    'Pins free assignment with Hijack by Darrel Taylor [http://www.picbasic.co.uk/forum/showthread.php?t=7038]
    LCD_DB4    VAR PORTB.4
    LCD_DB5    VAR PORTB.5
    LCD_DB6    VAR PORTB.6
    LCD_DB7    VAR PORTB.7
    LCD_RS     VAR PORTC.6
    LCD_E      VAR PORTC.7
    LCD_Lines  CON 2                    ' # of Lines on LCD, 1 or 2 (Note: use 2 for 4 lines)
    LCD_DATAUS CON 50                   ' Data delay time in us
    LCD_COMMANDUS CON 2000              ' Command delay time in us
    LoopCount VAR WORD
        PAUSE 1000
        PAUSE 1000
        NEXT LoopCount
    GOTO Main
    In both cases, it compiles well without error but with AnyPin, the screen seems not initializing.
    Cause AnyPin was realised before the 2.60C PBP ver., is there a compatibility issue ?
    Thanx a lot for any help.
  28. #108
    LCD_AnyPin works with all versions of PBP from 2.46 and later.
    But you'll need to use the MPASM assembler.
    Which means you also need to change your @ DEVICE statement.
    @ __config _INTRC_OSC_NOCLKOUT & _WDT_OFF & _PWRTE_ON & _MCLRE_OFF & _CP_OFF & _CPD_OFF & _BOR_ON & _IESO_OFF & _FCMEN_OFF
    Don't forget to comment the default __config line in the 16F685.inc file in your PBP folder.
    And you have started a command sequence in your LCDOUT line ... but there's no command.
    That will do strange things to the LCD.
    After assembling with MPASM, and removing the LCDOUT line ... this is what I get with a 16F685 and PBP 2.60 ...
    Will this help to avoid issue with LCDOUT, which can't send $FE to display? since it considers $FE as instruction?
  30. #110
    LCD_DATAUS and LCD_COMMANDUS are constants that you must declare in your program. Shown in the first post of this thread.
    They are not optional.
    Wow, I haven't used this routine yet, but I have to admit I would have fallen victim to that pesky detail as well.
    I added a NOTE to post #1 in case it helps someone.
  31. #111
    The timings depend on the type of LCD controller. Ususally the defaults of the manual are OK in most cases.
    As Darrel stated they are not optional and should always be on the top of the program.
    I didn't mean the speeds, I mean not noticing they were no longer Defines, but Variables and Constants.
    I would have spent countless hours looking at my code.
  33. #113
    Even on the latest PBP version the DEFINES are there for the LCD setup.
    I realized now that you confused the LCD_anypin of Darrel's setup with the original LCD setup of PBP.
    Two different things...
Members who have read this thread : 11
