Anyone used a WAVECOM gsm modem ?
Results 1 to 5 of 5
    Jul 2007
    Cool wavecom+gps+pic
    Yes I have a lot of experince send me your mail I will send you pictures I dont know
    how to upload pictures here
    Hi Guys-
    I've used Wavecom modules in the Falcom Tango Module. Also the Telit modules, which I have a project with on at the moment. There are a few things to consider. If you want to use the available programming aids with these modules, and thus avoid using an external microprocessor, then consider that Telit uses the Python interpreter and the Wavecom modules have a whole development platform called Open AT based on 'C'. This is powerfully supported, and probably not for beginners. If you want to start by using just the AT command set for the modules, then probably the cheaper Telit solution would do for a start. Also the the Telit version of the Python language is easy to learn.
    Good luck
    Angus
    brighton
    Thanks guys for all your replies.
    i got the module for £40 so i am just wait for it to be delivered would keep you all posted.
    am only going to be doing basic sms controlled like turning relays on etc.
    not sure if its possible to do large data transfers Lo:
    Isaac
  1. Interface Pic --> Max232 --> GSM Modem
    By SangkiMangki in forum GSM
    Last Post: - 28th September 2013, 13:57
  2. Replies: 10
    Last Post: - 26th May 2008, 08:00
  3. Replies: 10
    Last Post: - 14th April 2007, 05:34
  4. PIC18F2550 and GSM modem
    By zach in forum GSM
    Last Post: - 28th November 2006, 10:01
  5. SEROUT2 to GSM Modem
    By tommyers in forum General
    Last Post: - 21st August 2006, 22:35
