What frequency do you run the PIC on? The faster you run it the more resolution you will get. My experience with Pulsin has been between great and failure and in the end I usually end up having to write my own code using a Timer. Timers are not that difficult to use and if you have a built in HPWM with capture and compare function it is not that bad at all :-)
If you don't have that Darryl's instant interupts can be used for this as well. Especially together with external interupt sources. or a simple if-then loop or wend or whatever loop is also ok.....
With a high ocs frequency and a timer you can get even parts of ms. 40 MHz would give you 0.1 ms in resolution. It would of course overflow the timer on low rpm's but then we just check for that and if it happens change the prescaler and try again... or we first do a Pulsin (same as now) to get the basic settings and then we do a new measurement right after using the best possible prescaler and a 16-bit timer to get a great value.
You said you wanted the FQ right? Do the measurement with a timer over a longer time (i.e 16 periods (the ccp can be set up to capture several periods by itself)). Then you will get an even better resolution, the more periods you measure over the better it will be. I guess the stuff you are measuring dont change rpms that crazy fast either. What is spinning?
/me
