Converting milliseconds to frequency
Results 1 to 23 of 23
    Aug 2007
    Question Converting milliseconds to frequency
    I have code written to measure the time period of a square waveform using pulsin . I measure the low time and the high time and add them together and send it to an LCD. It is quite accurate (comparing to scope) and the refresh time is fast as the frequency varies. Knowing that frequency is 1/time, how can one go about doing the math in PBP to calculate the frequency of this waveform? Thanks.
    This is either very easy or a bigger problem than it seems.
    Here is the main loop: I found that I needed to do the 4/5ths thing to get the time more accurate.
    loop: pulsin PORTA.1,0,x
    x = x / 100
    pulsin PORTA.1,1,y
    y = y / 100
    z = x + y
    z = z * 4
    z = z / 5
    LCDOUT $fe, $C0
    LCDOUT " "
    LCDOUT $fe, $C0
    LCDOUT #z
    Goto loop
    Perth, Australia
    i may be able to help, but ive got a few questions:
    is the variable z a byte or a word?
    what is the unit of z? *edit* Cancel that question... Just read the thread topic
    what resolution is required? i.e. whats the smallest change in frequency that you would need to detect?
    what is the highest and lowest frequency you need to detect?
    Aug 2007
    Thanks for the reply.
    I made all variables words to give myself plenty of room, at least for now.
    Ultimately, I want to get to pulses per minute, ie. RPMs with a range from maybe 240 RPM (4 cycles per sec) to maybe 4000 or 5000 (66 Hz to 85 Hz), give or take. I am flexible to a point. As far as resolution goes, something like 100 RPM increments (~2 Hz ?). Make any sense?
    Jul 2007
    Grass Valley CA
    Frequency is the reciprocal of time. For example, if you measure your square wave as 16.66...milliseconds, you have a 60 Hz. frequency.
    Now, dependent on whether your milliseconds are floating point (many decimal places), you can measure frequency with concomitant resolution. That is, if time is an integer and you only have choices of 16 or 17 milliseconds, the frequency comes out 62 Hz. or 58 Hz. respectively while the actual waveform is 60 Hz..
    Jim
    Aug 2007
    With my millisecond values are integers, I don't expect 100% accuracy. Using PBP, how do I get from say, 16mS to 62Hz ?
    Scott
    Perth, Australia
    You can write a subroutine to determine the RPM from the z value. If to the nearest 100rpm is acceptable, this is the relevant data:
    z           rpm
    <10         out of limits
    10          6000
    11          5500
    12          5000
    13          4600
    14          4300
    15          4000
    16          3800
    17          3500
    18          3300
    19          3200
    20          3000
    21          2900
    22          2700
    23          2600
    24          2500
    25          2400
    26          2300
    27          2200
    28-29       2100
    30          2000
    31-32       1900
    33-34       1800
    35-36	    1700
    37-38	    1600
    39-41	    1500
    42-44	    1400
    45-48	    1300
    49-52	    1200
    53-57	    1100
    58-63	    1000
    64-70	    900
    71-80       800
    81-92       700
    93-109      600
    110-133     500
    134-171     400
    172-240     300
    241-400     200
    401-1200    100
    >12000      out of limits
    If you need help on how to write a subroutine to do this then let me know and i can help you out.
    Aug 2007
    I am a bit of a rookie. Some direction would be much appreciated.
    Perth, Australia
    I had a few spare mins so i wrote up a subroutine that would work. Im sure its not the most elegant piece of code, but it will do what you want just fine.
    It will take the z value and store a relavant value into rpm. The value in rpm will be in hundreds of rpms. So if you write the value of the variable rpm to your lcd, followed by "00" it will display in rpms.
    If rpm=0 after the subroutine has run then the input was out of range.
    convert_to_rpm:
    IF z<10 THEN rpm=0
    IF z=10 THEN rpm=60
    IF z=11 THEN rpm=55
    IF z=12 THEN rpm=50
    IF z=13 THEN rpm=46
    IF z=14 THEN rpm=43
    IF z=15 THEN rpm=40
    IF z=16 THEN rpm=38
    IF z=17 THEN rpm=35
    IF z=18 THEN rpm=33
    IF z=19 THEN rpm=32
    IF z=20 THEN rpm=30
    IF z=21 THEN rpm=29
    IF z=22 THEN rpm=27
    IF z=23 THEN rpm=26
    IF z=24 THEN rpm=25
    IF z=25 THEN rpm=24
    IF z=26 THEN rpm=23
    IF z=27 THEN rpm=22
    IF z>27 AND z<30 THEN rpm=21
    IF z=30 THEN rpm=20
    IF z>30 AND z<33 THEN rpm=19
    IF z>32 AND z<35 THEN rpm=18
    IF z>34 AND z<37 THEN rpm=17
    IF z>36 AND z<39 THEN rpm=16
    IF z>38 AND z<42 THEN rpm=15
    IF z>41 AND z<45 THEN rpm=14
    IF z>44 AND z<49 THEN rpm=13
    IF z>48 AND z<53 THEN rpm=12
    IF z>52 AND z<58 THEN rpm=11
    IF z>57 AND z<64 THEN rpm=10
    IF z>63 AND z<71 THEN rpm=9
    IF z>70 AND z<81 THEN rpm=8
    IF z>80 AND z<93 THEN rpm=7
    IF z>92 AND z<110 THEN rpm=6
    IF z>109 AND z<134 THEN rpm=5
    IF z>133 AND z<172 THEN rpm=4
    IF z>171 AND z<241 THEN rpm=3
    IF z>240 AND z<401 THEN rpm=2
    IF z>400 AND z<1201 THEN rpm=1
    IF z>1200 then rpm=0
    Aug 2007
    Thanks. A bunch of if-thens came to my mind as well. I just was not sure about it. I think I'll try it.
    Apr 2007
    Quote Originally Posted by chips123 View Post
    Scott
    Time and Frequency are reciprocal, so you can use a constant (in this case 1000) and divide you mS value into it. For example:
    1000 / 16mS = 62Hz.
    Or if you had 40mS -
    1000 / 40mS = 25Hz etc.
    You are probably kicking yourself right about now
    Andy
    Perth, Australia
    That would work, but that kind of division in PBP would take up a lot more processing time than the IF...THEN statements above.
    Omaha, Nebraska USA
    I may not be understanding something here.
    For the basic math, I would have said:
    rpm=60000/z
    where z is in milliseconds.
    My question is: Why would doing that single division take longer than going through multiple IF...THEN statements (40-something of them in the example) until one is found where the condition is satisfied?
    Thanks to whomever clarifies this for me!
    Russ
    N0EVC, xWB6ONT, xWN6ONT
    "Easy to use" is easy to say.
    Jul 2007
    Question Then, when should we use lookup ???
    All this thread bring back a question that I had in mind for a while. I was wondering at which point is that better (faster) to use lookup instead of calculated values?
    I know that I can find thread like "Sine wave power inverter" where a lookup table was used to increase calculation's speed. But is this only a trial an error process or can someone bring up guidelines that will lead to use one solution or the other?
    J-P
    Question
    One more thought . . . instead of 40 IF THEN loops would't SELECT CASE be more appropriate? I throw this out there, having NEVER used select case, because you see, I want to learn too . . .
    Omaha, Nebraska USA
    I'm sure that SELECT CASE could be used, or LOOKDOWN (or should it be LOOKUP?), depending on the strategy, and maybe more effectively than IF...THENs. In all of those cases, though, it still looks like a bulky approach. I'm still not convinced that the single 16-bit division isn't going to be not only simpler but faster.
    Any thoughts? Is this one of those balancing acts between compact code and speed of operation?
    Scott, how often do you need to update the display with new information?
    Russ
    Here is all the IF/THENS in ASM
    	LABEL?L	_convert_to_rpm
    	CMPGE?BCL	_z, 00Ah, L00001
    	MOVE?CB	000h, _rpm
    	LABEL?L	L00001
    	CMPNE?BCL	_z, 00Ah, L00003
    	MOVE?CB	03Ch, _rpm
    	LABEL?L	L00003
    	CMPNE?BCL	_z, 00Bh, L00005
    	MOVE?CB	037h, _rpm
    	LABEL?L	L00005
    	CMPNE?BCL	_z, 00Ch, L00007
    	MOVE?CB	032h, _rpm
    	LABEL?L	L00007
    	CMPNE?BCL	_z, 00Dh, L00009
    	MOVE?CB	02Eh, _rpm
    	LABEL?L	L00009
    	CMPNE?BCL	_z, 00Eh, L00011
    	MOVE?CB	02Bh, _rpm
    	LABEL?L	L00011
    	CMPNE?BCL	_z, 00Fh, L00013
    	MOVE?CB	028h, _rpm
    	LABEL?L	L00013
    	CMPNE?BCL	_z, 010h, L00015
    	MOVE?CB	026h, _rpm
    	LABEL?L	L00015
    	CMPNE?BCL	_z, 011h, L00017
    	MOVE?CB	023h, _rpm
    	LABEL?L	L00017
    	CMPNE?BCL	_z, 012h, L00019
    	MOVE?CB	021h, _rpm
    	LABEL?L	L00019
    	CMPNE?BCL	_z, 013h, L00021
    	MOVE?CB	020h, _rpm
    	LABEL?L	L00021
    	CMPNE?BCL	_z, 014h, L00023
    	MOVE?CB	01Eh, _rpm
    	LABEL?L	L00023
    	CMPNE?BCL	_z, 015h, L00025
    	MOVE?CB	01Dh, _rpm
    	LABEL?L	L00025
    	CMPNE?BCL	_z, 016h, L00027
    	MOVE?CB	01Bh, _rpm
    	LABEL?L	L00027
    	CMPNE?BCL	_z, 017h, L00029
    	MOVE?CB	01Ah, _rpm
    	LABEL?L	L00029
    	CMPNE?BCL	_z, 018h, L00031
    	MOVE?CB	019h, _rpm
    	LABEL?L	L00031
    	CMPNE?BCL	_z, 019h, L00033
    	MOVE?CB	018h, _rpm
    	LABEL?L	L00033
    	CMPNE?BCL	_z, 01Ah, L00035
    	MOVE?CB	017h, _rpm
    	LABEL?L	L00035
    	CMPNE?BCL	_z, 01Bh, L00037
    	MOVE?CB	016h, _rpm
    	LABEL?L	L00037
    	CMPGT?BCB	_z, 01Bh, T1
    	CMPLT?BCB	_z, 01Eh, T2
    	LAND?BBW	T1, T2, T2
    	CMPF?WL	T2, L00039
    	MOVE?CB	015h, _rpm
    	LABEL?L	L00039
    	CMPNE?BCL	_z, 01Eh, L00041
    	MOVE?CB	014h, _rpm
    	LABEL?L	L00041
    	CMPGT?BCB	_z, 01Eh, T1
    	CMPLT?BCB	_z, 021h, T2
    	LAND?BBW	T1, T2, T2
    	CMPF?WL	T2, L00043
    	MOVE?CB	013h, _rpm
    	LABEL?L	L00043
    	CMPGT?BCB	_z, 020h, T1
    	CMPLT?BCB	_z, 023h, T2
    	LAND?BBW	T1, T2, T2
    	CMPF?WL	T2, L00045
    	MOVE?CB	012h, _rpm
    	LABEL?L	L00045
    	CMPGT?BCB	_z, 022h, T1
    	CMPLT?BCB	_z, 025h, T2
    	LAND?BBW	T1, T2, T2
    	CMPF?WL	T2, L00047
    	MOVE?CB	011h, _rpm
    	LABEL?L	L00047
    	CMPGT?BCB	_z, 024h, T1
    	CMPLT?BCB	_z, 027h, T2
    	LAND?BBW	T1, T2, T2
    	CMPF?WL	T2, L00049
    	MOVE?CB	010h, _rpm
    	LABEL?L	L00049
    	CMPGT?BCB	_z, 026h, T1
    	CMPLT?BCB	_z, 02Ah, T2
    	LAND?BBW	T1, T2, T2
    	CMPF?WL	T2, L00051
    	MOVE?CB	00Fh, _rpm
    	LABEL?L	L00051
    	CMPGT?BCB	_z, 029h, T1
    	CMPLT?BCB	_z, 02Dh, T2
    	LAND?BBW	T1, T2, T2
    	CMPF?WL	T2, L00053
    	MOVE?CB	00Eh, _rpm
    	LABEL?L	L00053
    	CMPGT?BCB	_z, 02Ch, T1
    	CMPLT?BCB	_z, 031h, T2
    	LAND?BBW	T1, T2, T2
    	CMPF?WL	T2, L00055
    	MOVE?CB	00Dh, _rpm
    	LABEL?L	L00055
    	CMPGT?BCB	_z, 030h, T1
    	CMPLT?BCB	_z, 035h, T2
    	LAND?BBW	T1, T2, T2
    	CMPF?WL	T2, L00057
    	MOVE?CB	00Ch, _rpm
    	LABEL?L	L00057
    	CMPGT?BCB	_z, 034h, T1
    	CMPLT?BCB	_z, 03Ah, T2
    	LAND?BBW	T1, T2, T2
    	CMPF?WL	T2, L00059
    	MOVE?CB	00Bh, _rpm
    	LABEL?L	L00059
    	CMPGT?BCB	_z, 039h, T1
    	CMPLT?BCB	_z, 040h, T2
    	LAND?BBW	T1, T2, T2
    	CMPF?WL	T2, L00061
    	MOVE?CB	00Ah, _rpm
    	LABEL?L	L00061
    	CMPGT?BCB	_z, 03Fh, T1
    	CMPLT?BCB	_z, 047h, T2
    	LAND?BBW	T1, T2, T2
    	CMPF?WL	T2, L00063
    	MOVE?CB	009h, _rpm
    	LABEL?L	L00063
    	CMPGT?BCB	_z, 046h, T1
    	CMPLT?BCB	_z, 051h, T2
    	LAND?BBW	T1, T2, T2
    	CMPF?WL	T2, L00065
    	MOVE?CB	008h, _rpm
    	LABEL?L	L00065
    	CMPGT?BCB	_z, 050h, T1
    	CMPLT?BCB	_z, 05Dh, T2
    	LAND?BBW	T1, T2, T2
    	CMPF?WL	T2, L00067
    	MOVE?CB	007h, _rpm
    	LABEL?L	L00067
    	CMPGT?BCB	_z, 05Ch, T1
    	CMPLT?BCB	_z, 06Eh, T2
    	LAND?BBW	T1, T2, T2
    	CMPF?WL	T2, L00069
    	MOVE?CB	006h, _rpm
    	LABEL?L	L00069
    	CMPGT?BCB	_z, 06Dh, T1
    	CMPLT?BCB	_z, 086h, T2
    	LAND?BBW	T1, T2, T2
    	CMPF?WL	T2, L00071
    	MOVE?CB	005h, _rpm
    	LABEL?L	L00071
    	CMPGT?BCB	_z, 085h, T1
    	CMPLT?BCB	_z, 0ACh, T2
    	LAND?BBW	T1, T2, T2
    	CMPF?WL	T2, L00073
    	MOVE?CB	004h, _rpm
    	LABEL?L	L00073
    	CMPGT?BCB	_z, 0ABh, T1
    	CMPLT?BCB	_z, 0F1h, T2
    	LAND?BBW	T1, T2, T2
    	CMPF?WL	T2, L00075
    	MOVE?CB	003h, _rpm
    	LABEL?L	L00075
    	CMPGT?BCB	_z, 0F0h, T1
    	CMPLT?BCB	_z, 00191h, T2
    	LAND?BBW	T1, T2, T2
    	CMPF?WL	T2, L00077
    	MOVE?CB	002h, _rpm
    	LABEL?L	L00077
    	CMPGT?BCB	_z, 00190h, T1
    	CMPLT?BCB	_z, 004B1h, T2
    	LAND?BBW	T1, T2, T2
    	CMPF?WL	T2, L00079
    	MOVE?CB	001h, _rpm
    	LABEL?L	L00079
    	CMPLE?BCL	_z, 004B0h, L00081
    	MOVE?CB	000h, _rpm
    	LABEL?L	L00081
    	GOTO?L	_convert_to_rpm
    And here is the WORD division in ASM.
    	LABEL?L	_TEST
    	MOVE?CW	003E8h, _FREQ
    	MOVE?CW	010h, _SPEED
    	DIV?WWW	_FREQ, _SPEED, _ROTATIONS
    	GOTO?L	_TEST
    Do not know about CASE either.
    Omaha, Nebraska USA
    Thumbs up
    Thanks, Dave! That was a lot of extra effort to answer the question, but I appreciate it. I'm sure others will, too!
    Scott--what do you think?
    Russ
  1. HPWM command and oscillator frequency
    By RussMartin in forum mel PIC BASIC Pro
    Last Post: - 8th March 2009, 23:41
  2. HPWM10 Frequency Updating
    By duncan303 in forum mel PIC BASIC Pro
    Last Post: - 19th January 2008, 13:30
  3. How do I convert an internal variable into frequency
    By schlaray in forum mel PIC BASIC Pro
    Last Post: - 13th February 2007, 08:26
  4. inaccurate frequency using TMR1 PI18F452
    By nkarpovich in forum mel PIC BASIC Pro
    Last Post: - 14th October 2006, 17:22
  5. frequency measurement
    By big-x in forum General
    Last Post: - 25th November 2005, 01:53
