Very Simple ICSP Programmer
Page 1 of 2 12 LastLast
Results 1 to 40 of 130
    Oct 2003
    Australia
    Talking Very Simple ICSP Programmer
    Hi guys,
    I have been using this simple programmer.. why pay big bucks for a PIC programmer when this one costs just cents! In fact I have stopped using my 'other programmer' all together now.
    All you need is:
    three 4.7k Resistors,
    a few wires (1m)
    9 pin d-connector (female),
    and a 5 volt dc supply.
    I have used it on 16F84, 16F62X, 16F87X chips without problems.
    To make it:
    TXD (3) ------[4.7k]-------VPP
    GND (5) --------------------VSS
    DTR (4) -------[4.7k]------DATA
    CTS (8) ------------------DATA
    RTS (7) -------[4.7k]------CLK
    Numbers in Bracket are the connections on the 9-Pin D-Connector.
    I have made up a small PCB to mount the resistors on but... you could just solder them in line to go cheap.. Just be carefull they dont short out. If anyone wants the PCB footprint I can post it.
    Then just put your PIC into a breadboard, connect your 5 volt supply to VDD/VSS, and away you go.
    Question
    Looks neat.
    What software are you using on the PC?
    Oct 2003
    Australia
    Feb 2004
    Germany
    If you are looking for a cheap programmer have a look at:
    http://www.olimex.com/dev/pic-pg2c.html
    it is a JDM-type of programmer, it has an ICSP connector and doesn't even need an external power supply.
    The assembled Programmer is $9.95 only.
    regards
    Dec 2003
    Wichita KS
    Hello Ralph,
    Yes, My friend bought one of those programmers. They have them on Ebay for 15 dollars delivered. He likes it.
    the only thing he doesn't like about it, is not ZIF socket. got to be careful on removing the chips.
    Also, (IF i remember correctly) the programmer does *not* list the 16f648A chip as a programmable chip, but lists the 16f628. Since the chips are interchangeable, he has been programming the 16F648A with the 16F628 include file. Works like a charm...<g>
    Dwayne
    Ability to Fly:
    Pilots that are Flying:
    Oct 2003
    Australia
    That programmer looks good.
    However when you convert the cost of the programmer plus the freight into Aussie dollars.... it starts getting more expensive.
    Cheers
    Feb 2004
    Germany
    Dwayne,
    youe are right, ICprog doesn't support the 16F648, but thhere is another free software for serial programmers that does,
    see:
    http://www.qsl.net/dl4yhf/winpicpr.html
    regards:
    Ralph
    Which programmer do u choose in the ic-prog??
    Feb 2004
    Germany
    JDM-Programmer
    Direct I/O
    I/O Delay 20
    regards:
    Ralph
    Thanks.
    USA - Arizona
    Smile
    Have any of you been able to use this with a USB-Serial adapter? When I moved laptops, the new one only had USB ports and I was not able to use it with a USB-serial adapter. I can still use it with the old one, but since the topic was brought-up I figure I asked.
    Feb 2004
    Germany
    As the programmer is powered by the serial port I doubt it works with a USB-Serial adapter.
    regards
    Ralph
    toreto's Avatar
    toreto Guest
    Question
    does this work for 12c508a chip?
    Oct 2003
    Australia
    I don't know.. I have only ever used the 16F**** type chips.
    If the 12c508a chip supports ICSP then probably does.
    J
    toreto's Avatar
    toreto Guest
    Thumbs up
    ok thanks Squibcakes
    toreto's Avatar
    toreto Guest
    Question
    can you tell me which pins of 12c508 are VPP,VSS,DATA,DATA,CLK.
    thanks.
    thanks.
    here they are
    VPP = 4
    VSS = 8
    PGD = 7
    PGC = 6
    VDD =1
    toreto's Avatar
    toreto Guest
    Question
    which of this two is conected to the resitor?
    PGD = 7
    PGC = 6
    thanks for your answer
    sorry for the late reply,
    well i never use serie resistor for PGD, PGC for all my purpose i do like this.
    http://www.melabs.com/support/icsp.htm
    hope this help
    regards
    Oct 2003
    Australia
    PGD = 7
    PGC = 6
    Both are connected through 4.7k resistors, as well as the vpp through a 4.7k resistor.
    GP0 = GPD = 7
    GP1 = GPC = 6
    So in your case you would connect the 12Cxxx chip like this:
    D-Conn............................uPIC
    TXD (3) ------[4.7k]-------VPP(pin 4)
    GND (5) --------------------VSS(pin 8)
    DTR (4) -------[4.7k]------DATA(pin 7)
    CTS (8) ------------------DATA(pin 7)
    RTS (7) -------[4.7k]------CLK(pin 6)
    5 volts DC to VDD(pin1)
    Hope this helps.
    J
    Nimrod's Avatar
    Nimrod Guest
    Quote Originally Posted by Squibcakes View Post
    GP0 = GPD = 7
    GP1 = GPC = 6
    Hope this helps.
    J
    I've tried to make this programmer but somehow I can't program the 12C508a, here is what happends:
    I can read the PIC with no problems in ICprog but when I press the program button it gives me an error on 0000h I've checked the Voltage and I have 5V between GND and VCC as expected (I'm powering the programmer through USB since it gives 5V) and between GND and VPP I have -10V without the PIC placed in the socket ofc...its a bit strange to have a value so low isn't it? Can anyone please help me I'm getting crazy with this already screwed 3 PICS...can read them but cant write Thnx
    10V is way too low, this have to be ~13V. This kind of programmer is really not recommended anyways.. worst if you use a USB to Serial converter.
    There's few variant of such cheap programmer like JDM, JDM2, Taits, Ludipo, ElCheapo, PicBlaster and the list is long... none of those seems to work properly... even worst with Vista
    I've been told the parrallel PIC programmer in the list above work better... BUT ANYWAY...invest ~40$ and buy yourself a real Microchip PICKit 2 or a clone like JuneBug.
    and huh.. why not using 12F508 wich is a flash version.. so you can write on it again and again... and again.
    Yet another reason why you should consider PICKit2. Along with it's ICD capability, EEPROM, Keeloq and device programming list, The standalone application give you USART tool (no need for MAX232)... AND NOW, the new V2.50 add this nifty 3 channel LogicAnalyser (logic signal stimulus and monitoring) tool... for free!
    As if wasn't enough... >>>PICkit 2 Programmer-To-Go support for programming devices without a PC.<<<
    http://www.microchip.com/stellent/id...cName=en023805
    How about that?
    ~40$ for that... even if you don't use it as a daily/main programmer... only the free tools worth it no? I really like the Programmer-To-Go option....
    Apr 2008
    Can you update the schematic to be used with 18F452 ?
    Ramon.
    Nov 2013
    Default Re: Very Simple ICSP Programmer
    Hi
    I am completely new to PIC, so please excuse if this is stupid.
    For Stand-alone(not in-circuit) I understand that to transfer a program I need approx 12V on VPP and this has to be connected after 5V to VDD.
    Can I use an external power supply for both voltages and make the VPP 12V switched in by the VDD 5v via a transistor, can it work or is VPP switched during transfer?
    So I will then only have these between PC and PIC
    If it can work, then surely it will solve the laptop and USB-232 adapter problems.
    Ps. I know I can buy a programmer, but I want to build one. This is why I ask.
    Will appreciate your help.
    toreto's Avatar
    toreto Guest
    Post thanks
    i am goin to test it and i will post the results.thanks
    Default pic-pg2 programmer cable
    I have made pic-pg2 programmer. But I havent got any idea connecting rs232 cable to the device.
    I cant find any schematics in net...
    I have an RS232 cable connecting 1-1,2-3,3-2,5-5 but cant connect with this one.
    Could u please tell me how can I connect the RS232 cable?
    Thanks.
    mslaney's Avatar
    mslaney Guest
    microcozmoz,
    did you ever figure out how to connect your cable? What chip are you using?
    mslaney's Avatar
    mslaney Guest
    ICSP Sacrifice.
    It seems that I lose a couple I/O pins when I use ICSP. RB6 and RB7 specifically.
    I want to program the device then be able to use every IO on the chip. Is this possible without disconnecting the ICSP cable entirely?
    oh, microcozmoz, I will send you my schematic when I get back to my lab tonight.
    Depending what you want to do with those pins. Many here will use those PGD, PGC pin as push button inputs. You must design your circuit in regard to this issue.
    In the worst case, you can use an DPDT relay + 1 switch to toggle those pins manually between PROGRAMING and NORMAL use.
    For all of my application i use a 5 pins ICSP connector with an external switch box (circuit attach here) between my PICSTART and the taget PIC.
    PIN 5 (GND/PGM) is a switched Ground. This is use with some PIC that need GND to PGM (low voltage programming pin) when programming. You can use this pin for the relay trigger.
    Default ICSP
    Thanks for your replys....
    Actually I want to make a control circuit with ICSP...When I want to edit the program it will be usefull connect to circuit by notebook and programming device on a machine...
    I am very busy nowadays
    When I'll make the circuit I 'll write here...
    Thanks again.
    TONIGALEA's Avatar
    TONIGALEA Guest
    hi Squibcakes
    Does this support 16f627A?
    Toni
    Oct 2003
    Australia
    TONIGALEA,
    In short, no.
    (But) Yes for 16F84, 16F627, 16F628.
    I've used it successfully on 16F628 chips (F27's big brother), but recently I have found some of the F27/8A chips have problems erasing after a successful write.
    I found that these chips start up too fast when power is first applied.
    Hence this ICSP programmer isn't quick enough to pull the MCLR line high for the erase.
    As a work around, put 12volts on the MCLR pin before applying power will erase the chip (this method also a bit flakey).
    Since I started this post, I have revised the circuit and added a FET between 12volts and the MCLR line and this is fast enough for all PICS I have tried so far.
    Cheers
    J
    JoeCJK's Avatar
    JoeCJK Guest
    Default Can't write to PIC
    Hi Squibcakes,
    I connected the serial port pins to a 16F628 as specified in your simple programmer and ran IC-Prog to write to it. However, the verify always fails, meaning that the hex file is not written into it at all. Could you please suggest a way to fix this? Thanks!
    Feb 2004
    Germany
    Joe,
    would you let us know what exactly you have connected to which pins of the 16F628?
    See THIS
    and
    16F628 DataSheet
    Programming Specs
    ICSP-Guide
    regards
    Ralph
    JoeCJK's Avatar
    JoeCJK Guest
    Default connections with 16F628 and serial port
    thks for the reply. Pls bear with me for I am a novice programmer. I connected the 16F628 chip directly to the serial port in the config as shown below:
    Serial Port Pins : 16F628 Pins
    TXD (Pin 3) -----[4.7K]------ MCLR ( Pin 4)
    GND (Pin 5) ----------------- Vss (Pin 5)
    DTR (Pin 4 ) -----[4.7K]------ RB 7 (Pin 13)
    CTS (Pin 8) ----------------- RB 7 (Pin 13)
    RTS (Pin 7) -----[4.7K]------ RB 6 (Pin 12)
    To power up the chip, I connected the power supply to these pins on the 16F628.
    Vdd (Pin 14 ) ------ + 5V
    Vss ( Pin 5 ) ------ + 0V
    Afterwards, I used IC-Prog and did a wirte of a hex file but was unsuccessful. No other programmer was used, just a direct serial port to chip connection. By all indications it should work right?
    Feb 2004
    Germany
    Joe,
    There are a few things you could check in addition:
    What are the levels on you serial port?
    (if it's one of those LapTop ports with 5V levels this programmer is most likely NOT going to work).
    Another issue might be a floating LVP pin (RB4/PGM on the F628)
    See link "Programming Specs" posted earlier
    regards
    Ralph
    Apr 2006
    Question microchip programmer like picwin for programing 16f 676
    i have downloaded details about picwin programmer . in this diode bat 42 component is reqd. which is not available . can anyone suggest the equilent diode. suggest me some good programmer details
    NewBoy's Avatar
    NewBoy Guest
    Re: BAT 42
    I've found that BAT43, BAT48 and BAT85 all worked fine in my ICSP.
    I don't know anything about the programmer you mention but I guess they're simply specifying a small signal, fast, Schottky diode.
    If you don't mind a fatter diode then a 1N5818 will probably do.
    I've never tried a 'normal' signal diode, it may work, but no doubt you will messages of doom about them.
    BruMans's Avatar
    BruMans Guest
    i guess BAT42 can be replaced by 1N5820 Diode
  1. Melabs U2 Programmer Command Line Options
    By Robert Wells in forum General
    Last Post: - 3rd July 2009, 02:11
  2. Soic Icsp
    Last Post: - 13th September 2008, 19:51
  3. Replies: 1
    Last Post: - 10th December 2007, 23:57
  4. problems with USB programmer
    By malc-c in forum General
    Last Post: - 10th May 2007, 20:14
  5. USB programmer problems
    By uiucee2003 in forum USB
    Last Post: - 15th August 2006, 23:47
