PBPW out of memory error
Results 1 to 5 of 5
    Feb 2005
    Kolkata-India
    Unhappy PBPW out of memory error
    It has been some time that I have used PBP and while trying to maintain some 16F code it would not compile. Tried with old 18F codes and worked. Normally use MPASM but tried pbp's own assembler too. No luck. So looking for some suggestions before I start digging.
    Sougata
    Without a crystal ball, it's tough for anyone to help with code that refuses to compile..;o}
    Could you post the code that's giving you problems?
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    Feb 2005
    Kolkata-India
    Default Nothing would compile
    Thanks Bruce for responding. Just about anycode would give the same error for a 16F chip. Tried re-installing, didn't work.
    Goto Main
    Even the code above would not compile.
    Sougata
    Feb 2005
    Kolkata-India
    Default Found the problem.
    The files which would not compile (16Fs) were copied from a network computer so they were being blocked by the Windows Firewall. When I was trying to erase all the code and save it using the save as dialogue the same attributes were being passed off being in the same folder. (I guess) Thus the simplest code ever also would not compile. The 18Fs which were compiling were on the local system thus no issues. I thought it must be something with the PBP lib file. But it was all due to the windows firewall.
    Solution:
    Right click on the file and hit properties and click unblock, ok. This should let PBPW access it without any trouble.
    Sougata
    Glad you found that. I did something similar once over my home network, and it also returned
    some odd-ball errors. Now I just copy all files to all PCs' on the network for local copies.
    It's nice to have plenty of back-up copies of everything.
    -Bruce
    tech at rentron.com
  1. fatal: out of memory (pbpw) error
    By ardhuru in forum mel PIC BASIC Pro
    Last Post: - 24th February 2009, 08:33
  2. Loop with two motor and 2 sensors
  3. Optimizing DIV
    Last Post: - 22nd September 2008, 04:58
  4. 16F88 Compile error
    By Toley00 in forum mel PIC BASIC Pro
    Last Post: - 2nd November 2005, 00:22
  5. Compiler/Assembler Error
    By LT_Pic in forum General
    Last Post: - 21st July 2005, 09:47
