Help SERIN2/SEROUT2
Results 1 to 4 of 4
    Sep 2007
    Default Never seen PICBasic, but..
    Never done any pic programming, but a little basic back in the 80s - so might be completely off the mark here..
    Following the code from the top, it displays the menu, then drops through the options - because no valid key has been pressed.
    The code then eventually lands on bad: because there is no end point for main:
    'code
    goto getinput
    'there is no end statement here
    getinput:
    serin2 PORTC.7, $BC,[dec1 cmd] 'does this need to be told how many bytes to wait for? What does dec1 actually do?
    'the code should do a return here
    bad:
    'this code section is executed no matter what happens
    It appears that the program is returning to the last gosub statement it executed (ie none), perhaps filling the PC register with garbage? Or zeroes? or possibly the address of the program start point from the stack?
    Am I right in assuming also that the command in getinput:
    serin2 PORTC.7, $BC,[dec1 cmd] does not wait for an input? Instead it only checks the port and continues execution? If it is not told how many bytes to read, does the program assume that no bytes are acceptable input (or a byte value of 0, which is different from "0")?
    Try to avoid the use of GOTO statements unless absolutely necessary, and never use them to jump elsewhere in the program - it causes no end of grief.. Try to limit their use for loops that are designed to execute indefinitely. Use the GOSUB, IF/THEN, or BRANCH to jump around, it is much less hassle to debug.
    Try this fix - it is ugly, as it still uses a GOTO to continually loop for the check for input, but might be worth trying.
    Make these changes:
    {move}
    Serout2 PORTC.6, $BC,["Choose your Option",10,13]
    {up to the line before}
    goto getinput
    {..Then put a new label eg- checkser: BETWEEN those two lines}
    {Change}
    goto getinput
    {into}
    gosub getinput
    {then add a new GOTO after that}
    goto checkser
    getinput:
    if cmd = "4" Then
    GOSUB dispname
    {add the following line, so the program can go back and check for input}
    Your changed code should look something like this:
    'menu options
    goto getinput
    checkser:
    gosub getinput
    goto checkser
    getinput:
    'code to check choices
    Hope this helps.
    Sep 2007
    Default I've read a bit more..
    Another thing to look at:
    If what I read in the language guide is correct, then your IF..THEN statements are actually branching to a non-existent program label called gosub:
    Is it possible to compile that without raising an error?
    You may have to remove the GOSUBs and the ENDIFs from this bit of code (better make a copy of it lol):
    if cmd = "0" Then
    GOSUB bad
    if cmd = "1" Then
    GOSUB dosleep
    if cmd = "2" Then
    GOSUB doend
    if cmd = "3" Then
    GOSUB getname
    if cmd = "4" Then
    GOSUB dispname
    Assuming that the manual is correct, I can see why your blocks of IF..ENDIF are not working (not legal), but I am surprised if the compiler isn't catching that!
    Is it possible that your PIC is resetting when it encounters the first illegal IF..THEN construct? It would explain everything..
    Hi Mike,
    I think you should use the USART and setup a hardware buffer to capture the data choices as I do not believe the code you have will be in the appropriate state when your user is ready to answer the questions, check out Mr. E's keypad routines and the serial backpack code Darrel helped me with. good stuff there. also your main loop simply ends without a directive to goto main so it runs into the subroutines without meeting the criteria your IF THEN loops are asking for. You state hit CR to start the program. The program will simply start and run as is, perhaps a loop to test for a CR is in order so program will not execute beyond the instruction to hit CR until it actually sees a CR.
    something like:
    row var byte
    location var byte
    value var byte
    start:             SERIN 1,N2400,ROW,LOCATION,VALUE
                         IF value = CR then
                           goto start
    Darn I'm getting rusty at this as I have been working instead of coding . . .
  1. serin2/serout2
    By tazntex in forum Serial
    Last Post: - 19th September 2008, 22:01
  2. PIC to PIC "wired" serial one-way communication - SERIN2/SEROUT2
    Last Post: - 14th April 2008, 20:02
  3. Serin2/Serout2 Question
    By scottl in forum mel PIC BASIC Pro
    Last Post: - 18th November 2007, 09:11
  4. Serin2/Serout2 PIC 2 PIC
    By actionplus in forum mel PIC BASIC Pro
    Last Post: - 22nd March 2004, 06:46
