7805 works fine, LM2940CT5 not!
Results 1 to 5 of 5
    Default 7805 works fine, LM2940CT5 not!
    Hi All,
    I have a PIC application (16f88 and 2 leds) that is working fine with a 7805 (from National) and a 6 volts 1 amper battery.
    Yesterday, I replaced the 7805 with an LM2940CT5 (from National too) and my application didn't work. I tried with another LM2940CT5 and got the same result. I measure the input and the output and seemed ok. Just in case, tried another one, nothing happened.
    I switched back to the 7805 and everything worked again!!!
    I thought that the LM2940CT5 was better than the 7805, but is not.
    Any ideas why is not working with the LM2940CT5? I cannot find out why is not working.
    Thanks!
    Daniel.
    Mar 2004
    UK-Midlands
    Hi danielhr77,
    Make sure you have enough capacitance fitted both before and after the regulator. If too little or none they can oscillate which may not show on your meter?
    Check datasheet for correct smoothing and decoupling capacitance values.
    Bob
    Most +5V non LDO regulators require at least 7.5VDC minimum input to maintain a regulated +5V output.
    I couldn't find a datasheet for the LM2940CT5, but, some LDO types require specific capacitor values on
    the output or they will oscillate, and that causes major problems.
    Edit: I found a data sheet on the LM2940, and it looks like you need at least 22uF on the output, and
    drop-out will be around 0.5V, so you don't have much overhead.
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    Mar 2004
    UK-Midlands
    Hi Daniel,
    Just checked the datasheet
    http://www.national.com/ds/LM/LM2940.pdf#page=13
    and it clearly states that the mimimum capacitance on the 5volt side is 22uF (Pg13).
    Let us know if this solves the problem?
    Bob
    Edit oops Bruce has just giving this info
    Italy
    Datasheet:
    Application Note 1148 Linear Regulators:
    Theory of Operation and Compensation
    See page 7, Output Capacitor Selection:
    http://www.national.com/an/AN/AN-1148.pdf
    Source of the above PDF links:
    http://www.national.com/mpf/LM/LM2940C.html
    Best regards,
    Luciano
  1. Replies: 1
    Last Post: - 23rd May 2009, 10:22
  2. 24VAC Transformer from Air Handler, 7805
    By nemesis in forum Schematics
    Last Post: - 25th February 2009, 20:23
  3. Replies: 42
    Last Post: - 14th January 2008, 12:38
  4. 16f877a
    By dirkwerk in forum mel PIC BASIC Pro
    Last Post: - 19th November 2007, 23:01
  5. ERROR Compling 16F819...l but the 16F818 works fine
    By 4Lewis in forum mel PIC BASIC Pro
    Last Post: - 21st April 2006, 07:47
