MPASM problems
Results 1 to 5 of 5
Thread: MPASM problems
    Yup, compiles here too.
    Brian, can you open the .LST file for that program with Notepad.
    Search for [220].
    The lines immeadiately following the warning should indicate what the problem is from.
    Default thanks Darryl & Bruce
    Thanks guys,
    I have changed the file name and paths around and now get different error messages (Warning [217] ...path\filename....Hex file format specified on command line.) so I suspect I am running into some path\filename length issues.
    A challenge for the weekend.
    Cheers
    Brian
    Warning [217] is "Hex file format specified on command line."
    The path\filename is just the file the error occured in.
    INHX32 is required for the 4550, and the 18F4550.inc file specifies the format.
            LIST p = 18F4550, r = dec, w = -311, f = inhx32
    If specified on the command line, it throws the warning. Even if it's the same INHX32.
    The odd part is that MSC doesn't set the command line option when you select INHX8M.
    So selecting INHX8M in MCS should make the error go away.
    You still end up with INHX32.
  1. Moved from PM to MPASM and have fuse definition problems
    Last Post: - 26th November 2008, 23:27
  2. Problems with mpasm
    By electrosolve in forum mel PIC BASIC Pro
    Last Post: - 7th July 2008, 21:47
  3. 12F675 MCLR directive MPASM
    By OLDSCHOOL in forum mel PIC BASIC Pro
    Last Post: - 4th May 2008, 02:29
  4. MPASM 18F4550 getting started
    Last Post: - 5th September 2007, 00:59
  5. Converting to MPASM
    Last Post: - 4th November 2005, 02:35
