wake up from sleep
Results 1 to 5 of 5
    Jun 2006
    Default wake up from sleep
    I use pic16f628a with the code below.This code works.
    I want to change the code , so the pic after 10 seconds to wake up for .1 sec and after go again to sleep
        TRISB = %11110000
        TRISA = %00000000
        CMCON = 7
        OPTION_REG.7=0      ' 0 = Enable PORTB Pull Ups
        @ Device wdt_off    ' Disable the WatchDog Timer
        INTCON.3=1          ' Interrupt Control Register
        PORTB = 0
        PORTA = 0
    loop:
        PORTA.0 = 1         ' Turn LED On for 1 second
        PORTA.0 = 0
        INTCON.0=0
        @ SLEEP
        INTCON.0=0
        goto loop
    Hi Savnik,
    The device can wake-up from SLEEP through one of the following events:
    1. External RESET input on MCLR pin
    2. Watchdog Timer wake-up (if WDT was enabled)
    3. Interrupt from RB0/INT pin, RB Port change, or
    any Peripheral Interrupt.
    If you're not using option #1 or #3, then your left with the watchdog timer, but this has a
    period of around 18mS without the prescaler, and 128 * 18mS with a prescaler set to 128.
    OPTION_REG = %00001111 would assign the prescaler to the WDT, and give you roughly
    2.304 seconds before each wake-up from @ SLEEP.
    COUNTER=0 ' clear before entry
    WHILE COUNTER < 4
    @ SLEEP
    COUNTER=COUNTER+1
    WEND
    Would give roughly 9.2 seconds before exiting the loop, but it's still going to wake-up every
    2.304 seconds and increment COUNTER.
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    Jun 2006
    Hi Savnik,
    WHILE COUNTER < 4
    @ SLEEP
    COUNTER=COUNTER+1
    WEND
    I use Interrupt on RB4-7 Port change.
    I have 4 button on rb4-7 , and if i push any button the pic wake up from sleep
    and if i release the butoon the pic go again to sleep.
    Now i want the pic every 10 seconds to wake up for .1 sec (without to push any button) and after go again to sleep.
    Well, if you're not going to use the WDT, and you can spare RB6 and RB7, you could use a
    32,768kHz crystal with Timer1.
    @ DEVICE PIC16F628A,WDT_OFF,LVP_OFF,MCLR_OFF,INTRC_OSC,BOD_OFF
    SYMBOL LED = PORTB.0
    LED = 1           ' At POR, LED off after 1st toggle
    TRISB.0 = 0       ' LED pin an output
    TMR1H = $60       ' Pre-load TMR1 with $6001
    TMR1L = $01
    PIR1.0 = 0        ' Clear TMR1 overflow interrupt flag bit
    PIE1.0 = 1        ' TMR1 overflow interrupt enabled
    INTCON.6 = 1      ' Enable TMR1 peripheral interrupt
    T1CON = %00111111 ' External 32,768kHz crystal w\caps used, 1:8 prescale, TMR1 on
       TOGGLE LED     ' Indicates wake-up timing
       @ SLEEP        ' Goto sleep (for ~9.999 seconds)
       T1CON.0 = 0    ' Stop TMR1 on overflow wake-up
       TMR1H = $60    ' Re-load TMR1 with $6001
       TMR1L = $01
       PIR1.0 = 0     ' Clear TMR1 over-flow int flag
       T1CON.0 = 1    ' Re-start TMR1
       GOTO Main
    That would wake-up after sleep at roughly 10 second intervals without a button press. Do
    whatever you need for the .1 sec, then go back to sleep.
    -Bruce
    tech at rentron.com
    Jun 2006
    TMR1L = $01
       TMR1L = $01
       GOTO Main
    Thank you . I will try.
  1. 16F181: can't wake up from sleep
    By Navaidstech in forum mel PIC BASIC Pro
    Last Post: - 9th January 2010, 04:33
  2. Won't go back to SLEEP after 1st Interrupt
    Last Post: - 29th June 2009, 09:00
  3. 16F628A current high during sleep
    Last Post: - 9th October 2006, 10:21
  4. Wierd sleep issue
    By orca in forum mel PIC BASIC Pro
    Last Post: - 14th March 2006, 22:06
  5. 18F2320 and sleep function
    By Brian in forum mel PIC BASIC Pro
    Last Post: - 10th March 2005, 13:11
