DS18B20 does not work with extended wire
Results 1 to 3 of 3
    Ontario Canada
    Default DS18B20 does not work with extended wire
    I have run into a problem with reading temperature for the DS18B20. The sensor works fine plugged directly into the EasyPic4, but I extended the cable to 3 feet and triple checked the connections and it does not work. Does anyone know of this problem?
    Dec 2003
    WI
    Try a lower value pullup resistor. Something like 1.5k.
    Jason
    Ontario Canada
    Thank you. It worked.
  1. Please help with code for DS18B20
    Last Post: - 28th April 2013, 22:12
  2. Need Single wire serial LCD converter example
    By polymer52 in forum mel PIC BASIC Pro
    Last Post: - 16th December 2009, 03:30
  3. 24c16 vs 24lc256 and serial wire identification
    By inspired4real in forum mel PIC BASIC Pro
    Last Post: - 14th October 2008, 18:37
  4. blink.bas help cant make any 18f's work
    By Bonxy in forum mel PIC BASIC Pro
    Last Post: - 13th December 2004, 22:28
  5. Pin RA4 doesn't work
    Last Post: - 15th July 2004, 13:03
