ECCP module problem
Results 1 to 5 of 5
    Jun 2006
    Default still not working
    Hi!
    still not working!!!
    Is there more to your program?
    If not, then the FORWARD routine is RETURNing but it wasn't called with a GOSUB.
    Also,
    CCP1CON.4 = DUTY.0 ; here we stat loading the CCPR1
    CCP1CON.5 = DUTY.1 ; with the value of DUTY Cycle parameter
    CCPR1L = DUTY >> 2 ;
    CCP1CON = %01001100 ; set CCP1CON to full bridge , high output, Forward
    By setting CCP1CON after seting to 2 LSB's of the dutycycle, it overwrites those bits and you lose resolution.
    Jun 2006
    Default ok its done
    thanks its done with a little bit of messing around.i wasnt using my head and was relying too much on forum help.
    btw thanks to fanie & gabi as well.
  1. Version Control
    Last Post: - 16th October 2011, 17:12
  2. Problem displaying data from GPS module & using 16f877a
    Last Post: - 15th April 2010, 10:27
  3. Vinculum VNC1L Vdrive2 module problems
    By the_virus in forum Serial
    Last Post: - 21st July 2008, 07:01
  4. problem with sending data using RF module
    By rano_zen06 in forum mel PIC BASIC Pro
    Last Post: - 10th April 2008, 17:08
  5. Replies: 5
    Last Post: - 1st December 2004, 12:49
