sms send & recieving using pic16f84
Results 1 to 15 of 15
    Aug 2007
    sri lanka.rathnapura
    Default sms
    thank you mr gioppy.
    i following that forums.ican,n understand quekly.i will try it
    pic basic and pic basic pro are same lanauge.
    thank you
    Aug 2007
    Default sms
    hello.
    can you write me simple exmple.this one.i want to automaticaly send massag "hello" .16f84 portb.0 input signal.
    (tell me first i am this masage save in phone.then i writ program pic using at command.then send phone using data reciving pin)
    sorrey for my bad english.
    Aug 2007
    Default thanks
    thanks for all.to help me.
    I hope you are not being ironic...
    In case you don't, I have to say that such a project is not simple or for the novice. You must have a good understanding of serial communication and can suggest few books to read and of course hardware knoledge of the devices you are going to use.
    In the case of mobiles, you have to do 2 way communication with the device under control to make sure that all your settings are processed. Even a single AT must be replied with an OK and your PIC should received it before sending any new commands.
    Also every phone/module have additional commands special to itself.
    If you have written some code but want to check it or debug it, feel free to post it here.
    Aug 2007
    Default thank you
    i have a ericsson gf768 phone . i can,t find a t10 phone .
  1. Active low input?
    By CosMecc in forum mel PIC BASIC Pro
    Last Post: - 8th August 2010, 21:31
  2. Please send me a SMS program
    By hjcool in forum GSM
    Last Post: - 17th June 2009, 11:33
  3. Replies: 0
    Last Post: - 1st September 2008, 08:03
  4. sms send sht11 pic16f876 nokia 6210
    By elektoro2009 in forum GSM
    Last Post: - 9th June 2008, 09:57
  5. send incomming msg (SMS) to VB
    By PoTeToJB in forum mel PIC BASIC Pro
    Last Post: - 24th April 2006, 12:16
