sms send & recieving using pic16f84
Results 1 to 15 of 15
    Aug 2007
    sri lanka.rathnapura
    Smile sms send & recieving using pic16f84
    dear sir.
    i am ruwan i like to make using sms conrtol ather device,(light on or off and light on position automaticaly recived sms alert) please help me .thank you
    johor,Malaysia
    Default sending sms with pic 16f84
    hello...
    i success sending sms using pic16F84A..
    1st---what phone or modem u want use.
    2nd---the phone or modem must have at command
    3rd--- if use PIC16F84A must use 8Mhz because the speed.
    4th--- what languase u want use.(MPLAB,PIC BASIC PRO,C,PROTON)
    5----- u must know about serial comunication.
    hope this help u. sorry for my bad english...
    Aug 2007
    Smile sms project.
    dear friend.
    thank for ur help.
    don"t worry about your bad english.because my english allso bad.
    1st--nokia 3310.but i can chang it for ur advise
    02nd--no i haven"t any commond(at command)
    03rd--ok.i aggry with you
    04th--MPLAB and PIC BASIC PRO
    05TH-- NO
    i am a begener of thi kind of project.so can teach me A to Z
    thank you.
    johor,Malaysia
    ruwan
    i cant help u A to Z because i not master about this..
    this forum already talk about this. but now i cant find for give to you.
    if u want use nokia3310 that very difficult. u must know about F-bus or M-bus. i cant succes using the phone.
    u find the mobile phone with moden,something like sonyerricson t610 or other.
    t610 have at command so that easy to comunication with pic.
    for send the at command using pic basic pro u can use Serin2 and serout2.
    Aug 2007
    Default hello.
    i can find a sonyerriction t10 phone.
    ser in 2 and ser out 2 is enough
    please send to me for this project item list.i can collect.
    i followed pic programing short course and i can program led circuit and,7sigment ,
    there for i can do this project on ur help.
    thank you.
    johor,Malaysia
    Default need learn..
    hello..
    that time i built this project i dont know about Pic and Programming. just study and learn for other people topic... so u more good that me... heeheee
    t10 can use but the modem time is hex mode. that u must convert the hex kod.
    That more easy if can find modem with support text mode...
    can u describe about your project
    If your message do not change, you can store it in the sim card and send with the "AT+CMSS=" command.
    Gianni
    Aug 2007
    Default dear sir.
    i want to do.
    my home unit (include t10 phone & pic 16f84 )pic 16f84 ic portb.0 input some signal again i need to know that signal through sms to my hand phone.
    and i send sms my home unit again pic portb.1 high (out put signal)
    i am sorry to late my reply because my computer problem.
    thank you.
    Aug 2007
    hello.
    want to do.
    thank you.
    Aug 2007
    Default sms
    thank you mr gioppy.
    i following that forums.ican,n understand quekly.i will try it
    pic basic and pic basic pro are same lanauge.
    thank you
    Aug 2007
    Default sms
    hello.
    can you write me simple exmple.this one.i want to automaticaly send massag "hello" .16f84 portb.0 input signal.
    (tell me first i am this masage save in phone.then i writ program pic using at command.then send phone using data reciving pin)
    sorrey for my bad english.
    Aug 2007
    Default thanks
    thanks for all.to help me.
    I hope you are not being ironic...
    In case you don't, I have to say that such a project is not simple or for the novice. You must have a good understanding of serial communication and can suggest few books to read and of course hardware knoledge of the devices you are going to use.
    In the case of mobiles, you have to do 2 way communication with the device under control to make sure that all your settings are processed. Even a single AT must be replied with an OK and your PIC should received it before sending any new commands.
    Also every phone/module have additional commands special to itself.
    If you have written some code but want to check it or debug it, feel free to post it here.
    Aug 2007
    Default thank you
    i have a ericsson gf768 phone . i can,t find a t10 phone .
  1. Active low input?
    By CosMecc in forum mel PIC BASIC Pro
    Last Post: - 8th August 2010, 20:31
  2. Please send me a SMS program
    By hjcool in forum GSM
    Last Post: - 17th June 2009, 10:33
  3. Replies: 0
    Last Post: - 1st September 2008, 07:03
  4. sms send sht11 pic16f876 nokia 6210
    By elektoro2009 in forum GSM
    Last Post: - 9th June 2008, 08:57
  5. send incomming msg (SMS) to VB
    By PoTeToJB in forum mel PIC BASIC Pro
    Last Post: - 24th April 2006, 11:16
