HI, All
To anyone that is interested in the PBP Ethernet Driver for the PIC18F67J60, the code is now posted in the Download Area of www.edtp.com.
If there's enough interest, I will do an HTTP/TCP port for PBP as well..
Have fun,
Fred
HI, All
Have fun,
Fred
Nice work Fred.
Pheew! I had a look at your C firmware first. That was one heck of a LOT of work on
the port to PBP.
Thanks for sharing. I'm looking forward to reading your article. Probably have to get one
of your boards to tinker with here shortly.
I'd like to echo Bruce's comments. There is certainly interest from me on the HTTP/TCP port. I get the electronic version of Nuts and Volts, so I've already read the Sept. issue. Darrel will have to get a copy to frame now that he is forever immortalized in print. Nice work!
Wisdom is knowing what path to take next... Integrity is taking it.
Ryan Miller
Darrel should consider writing articles for Nuts & Volts, or Circuit Cellar (preferable). Maybe a series titled Power PBP....;o}
Well, since I'm "immortalized" for "tricky" DIV32 routines that he couldn't figure out how to make work.
I think I better skip the writing for magzines stuff.
what means this warning messages and why ?
my target will be 66j65...
after compiling and flashing pic replay to ping but http don't work , why ?
Executing: "C:\PBP\PBPW.EXE" -ampasmwin -oq -z -v -p18F67J60 "tcptester.bas"
PICBASIC PRO(TM) Compiler 2.47, (c) 1998, 2006 microEngineering Labs, Inc.
All Rights Reserved.
Pass 1:
Pass 2:
C:\DOCUMENTS AND SETTINGS\KRESO\DESKTOP\MINI\TCPTESTER.BAS WARNING Line 1316: $FF000000 Numeric overflow, value truncated.
C:\DOCUMENTS AND SETTINGS\KRESO\DESKTOP\MINI\TCPTESTER.BAS WARNING Line 1317: $00FF0000 Numeric overflow, value truncated.
C:\DOCUMENTS AND SETTINGS\KRESO\DESKTOP\MINI\TCPTESTER.BAS WARNING Line 1374: $FFFF0000 Numeric overflow, value truncated.
C:\DOCUMENTS AND SETTINGS\KRESO\DESKTOP\MINI\TCPTESTER.BAS WARNING Line 1539: $FF000000 Numeric overflow, value truncated.
C:\DOCUMENTS AND SETTINGS\KRESO\DESKTOP\MINI\TCPTESTER.BAS WARNING Line 1540: $00FF0000 Numeric overflow, value truncated.
C:\DOCUMENTS AND SETTINGS\KRESO\DESKTOP\MINI\TCPTESTER.BAS WARNING Line 1597: $FFFF0000 Numeric overflow, value truncated.
C:\DOCUMENTS AND SETTINGS\KRESO\DESKTOP\MINI\TCPTESTER.BAS WARNING Line 1658: $FF000000 Numeric overflow, value truncated.
C:\DOCUMENTS AND SETTINGS\KRESO\DESKTOP\MINI\TCPTESTER.BAS WARNING Line 1659: $00FF0000 Numeric overflow, value truncated.
C:\DOCUMENTS AND SETTINGS\KRESO\DESKTOP\MINI\TCPTESTER.BAS WARNING Line 1686: $FF000000 Numeric overflow, value truncated.
C:\DOCUMENTS AND SETTINGS\KRESO\DESKTOP\MINI\TCPTESTER.BAS WARNING Line 1687: $00FF0000 Numeric overflow, value truncated.
C:\DOCUMENTS AND SETTINGS\KRESO\DESKTOP\MINI\TCPTESTER.BAS WARNING Line 1745: $FFFF0000 Numeric overflow, value truncated.
Code Gen:
Macro Pass:
mpasmwin /q "C:\Documents and Settings\kreso\Desktop\mini\tcptester.ASM"
COD Pass:
Loaded C:\Documents and Settings\kreso\Desktop\mini\tcptester.COD.
BUILD SUCCEEDED: Thu Jan 10 18:36:59 2008
should this be because it must use PBP 2.50 with Longs var?
huh i understean... I was missing what mins "L" after pbp....
another thing to buy...
can i buy only "L"
I ordered the kit, read the October and December articles, and downloaded the zip files. While I'm waiting on the postman I was wondering if anyone knows how to place a variable in the TCP code. I would like to read an 18S20 or two, and display the results after the firmware sees the GET\ from the web browser.
Jerry.
If your oscilloscope costs more than your car...
I am very new on this. I bought Ethernet Mini kit and just finish it. Now I am working on 3.3 volts power supply with it. I am not sure how to run it. I understand we can connect it to the rounter. I have the dongle for it. But how do we use it? Do we connect it to person computer on telnet. Do we need some what kind of software or program that we can write small program on it. How? I am very new on this. There is free software that I can use it with it. Is there a tutorial for it? The last time I use 8085 with eprom on assembly language when I was in commuit college. Is there web page or free software that I can download and use it with Ethernet Mimi. Please contact me in person if you would like to help me with it. reidsim at gmail dot com
Thank you,
Reid
