Timer Application
Results 1 to 5 of 5
    Sep 2003
    INDIA
    Default Timer Application
    Hello Once again,
    I have a small application involving a Timer operation in which , on a press of a button , I have three LEDs that glow, The first LED switches off after 7 seconds, second LED switches off after 10 seconds and finally the third Switches OFF after 12 Seconds. The Duration of LEDs would change depending on different application.
    I am interested in doing this with the On Board Timer and PIC Basic Pro Compiler.
    Can anybody help me.
    Thank you.
    electronicsuk's Avatar
    electronicsuk Guest
    You could quite easily use PAUSE and a FOR/NEXT loop, assuming you have other tasks to process as well as working the LED's.
    Matthew
    This can be accomplished quite easily with the "Elapsed Timer Demo" found at http://www.picbasic.co.uk/forum/show...=&threadid=190
    In fact, you can do a lot of other things with it too. Since this thread is getting so many "Views" I assume that's what most people are really looking for.
    Darrel
    Sep 2003
    INDIA
    Thank you Darrel. I shall surely go thru it and get back to you.
    Dec 2003
    Wichita KS
    Hello Charudatt,
    Your program can use this example as a base,
    It could look something like the following:
    LED1 var GPIO.0 ; Or whatever pin works on your chip.
    LED2 var GPIO.1
    LED3 var GPIO.2
    FirstLed var byte
    SecondLed var byte
    ThirdLed var byte
    counter var byte
    Loop:
    ;Here your source gives you the values of the LED's length of time to stay on....
    FirstLed=7 ;these values you get from your source
    SecondLed=10
    ThirdLed=12
    ; Lets turn them all on!!!
    High LED1
    High LED2
    High LED3
    counter=FirstLed*1000
    Pause(counter);
    Low LED1;
    counter=(SecondLed-FirstLed*1000)
    Pause(counter);
    Low LED2;
    counter=ThirdLed-SecondLed*1000);
    Pause(counter);
    Low LED3;
    Goto Loop
  1. Elapsed Timer Demo
    Last Post: - 29th October 2012, 17:39
  2. High Resolution Timer & Speed Calculator
    By WOZZY-2010 in forum Code Examples
    Last Post: - 7th February 2010, 16:45
  3. Timer + rc5
    By naga in forum mel PIC BASIC Pro
    Last Post: - 19th November 2009, 07:56
  4. Timer interrupt frequency
    By Samoele in forum mel PIC BASIC Pro
    Last Post: - 17th January 2009, 23:49
  5. timer interupt help 16f73
    By EDWARD in forum mel PIC BASIC Pro
    Last Post: - 3rd July 2005, 08:41
