ds1820 error
Results 1 to 14 of 14
Thread: ds1820 error
    Hmmm, something doesn't seem right.
    The lower value pull-up, and pause 750 shouldn't be needed.
    The OWIn DQ, 4, [count_remain] will check the busy bit until the conversion is complete.
    ..... Unless it's running on "Parasite Power". In which case you need a Strong Pull-up on DQ during the conversion, and you can't read from the device for 750ms.
    If that fixed your problem, then you probably don't have 5V on pin 3 of the 1820.
    And if "Parasite Power" was intentional, you may need to do things differently.
    Nov 2006
    Melbourne, Australia
    Thumbs down
    Hi everyone
    Well this ds1820 ic is being a real pain. have gone over things with a multimeter and i have 5v going to pin 3. data is pin 2 and gnd is pin 1
    This is what the front of the ic looks
    ________
    dallas
    ds1820
    0634C3
    +552AC
    ________
    1 2 3
    GND 5V
    DATA
    2k4 resistor tied between pin 2 and pin 3
    I did notice "Vpu" figure 1 page 2 of the data sheet. What is Vpu is that the 5v line as i am using it. I assume it is. Could this be the problem??
    Am BALD cause of this ic. hahaha
    IF ITS STOCK IT WONT ROCK
    Yes, Vpu is VDD or +5V.
    If you have time, can you try this...
    Done      VAR BIT
    Parasite  VAR BIT
    Family    VAR BYTE
    Diag:
        OWIn DQ, 4, [Done]
        LCDOUT $FE,1,"Done =", bin1 Done
        OWOUT DQ, 1, [$CC, $B4] ' READ POWER SUPPLY
        OWIn DQ, 4, [Parasite]
        LCDOUT $FE,$C0,"Power="
        if Parasite = 0 then
            LCDOUT "Parasite"
            LCDOUT "VDD"
        OWOUT DQ, 1, [$33]
        OWIN  DQ, 2,[Family]
        LCDOUT $FE,$89,"FAM=",IHEX2 Family
        PAUSE 1000
    goto Diag
    Just stick it before the main loop in your program.
    Ideally, you should see this on the LCD ...
    Done = 1  FAM=$10
    Power=VDD
    Nov 2006
    Thanks darren you have been a big help.
    The program initialy comes up with
    Done =1 FAM=$10
    Power=VDD
    then half second later changes to
    Done =1 FAM=$10
    Power=Parasite
    crazy cooter
    Well, it's reporting the correct Family number so the communications is working.
    But as suspected, it's also reporting that there's no power on VDD Pin 3.
    Since you said you already verified that there is +5V on Pin 3.
    The only thing left, is to say that that particular part has a problem with it's power pin.
    Maybe it was plugged in backwards at some point along the way.
    The rest still seems to be working, I guess you can just use it in Parasite mode.
    But you may want to approach it differently than just a smaller Pull-Up resistor.
    HTH,
    &nbsp; Darrel
    Nov 2006
    Ok i i flipped the wires on the ds1820 around (PIN1=3 PIN2=2 PIN3=1)
    And now get
    Done =1 FAM=$FF
    Power=VDD
    When i put a 10K pullup resistor on i get
    Done =1 FAM=$10
    Power=Parasite
    when i take the resistor away i get
    Done =0 FAM=$00
    Power=Parasite
    I flipped the ic around and get these readings
    Done =1 FAM=$FF
    Power=VDD
    Done =1 FAM=$FF
    Power=VDD
    Does anyone have these problems?
    Regards CC
  1. Using input from Switch to control a loop
    Last Post: - 2nd February 2009, 06:02
  2. Loop with two motor and 2 sensors
  3. Optimizing DIV
    Last Post: - 22nd September 2008, 05:58
  4. 16F88 Compile error
    By Toley00 in forum mel PIC BASIC Pro
    Last Post: - 2nd November 2005, 01:22
  5. Compiler/Assembler Error
    By LT_Pic in forum General
    Last Post: - 21st July 2005, 10:47
