ds1820 error
Results 1 to 14 of 14
Thread: ds1820 error
    Nov 2006
    Melbourne, Australia
    Exclamation ds1820 error
    hi all. think i got the correct spot. i am having a issue with the dallas ds1820 temp sensor. i know it has been written many times. but think this is a different issue. i keep getting the same temp (85.00 deg c) even when i put the hair drier on it. is it stuffed????????
    my code for a 16f88 internal osc set at 4 mhz
    OSCCON = %01101000 'INTRC = 4 MHz
    TRISA = %11111111
    ANSEL = 0 'DISABLE ALL ADC
    CMCON = 7 'DISABLE ALL ANALOG COMPARATOR
    WHILE OSCCON.2=0:WEND 'STABILISE THE CLOCK
    ADCON1 = 1
    PAUSE 1000
    DEFINE LCD_DREG PORTB
    DEFINE LCD_DBIT 4 '4,5,6,7
    DEFINE LCD_RSREG PORTB
    DEFINE LCD_RSBIT 3
    DEFINE LCD_EREG PORTB
    DEFINE LCD_EBIT 2
    DEFINE LCD_BITS 4
    DEFINE LCD_LINES 2
    DEFINE LCD_COMMANDUS 2000
    DEFINE LCD_DATAUS 50
    lcdout $fe, 1
    ' One-wire temperature for DS18S20
    ' This program must be compiled with PBP version 2.40 or later
    temperature VAR WORD ' Temperature storage
    count_remain VAR BYTE ' Count remaining
    count_per_c VAR BYTE ' Count per degree C
    DQ VAR PORTA.1 ' One-wire data pin
    mainloop: OWOUT DQ, 0, [$B4] ' READ POWER SUPPLY
    OWOut DQ, 1, [$CC, $44] ' Start temperature conversion
    waitloop: OWIn DQ, 4, [count_remain] ' Check for still busy converting
    IF count_remain = 0 Then waitloop
    OWOut DQ, 1, [$CC, $BE] ' Read the temperature
    OWIn DQ, 0, [temperature.LOWBYTE, temperature.HIGHBYTE, Skip 4, count_remain, count_per_c]
    ' Calculate temperature in degrees C to 2 decimal places (not valid for negative temperature)
    temperature = (((temperature >> 1) * 100) - 25) + (((count_per_c - count_remain) * 100) / count_per_c)
    LCDOut $fe, 1, DEC (temperature / 100), ".", DEC2 temperature, " C"
    ' Calculate temperature in degrees F to 2 decimal places (not valid for negative temperature)
    temperature = (temperature */ 461) + 3200
    LCDOut $fe, $c0, DEC (temperature / 100), ".", DEC2 temperature, " F"
    Pause 500 ' Display about once a second
    LCDOUT $FE, 1, "DALLAS DS1820"
    PAUSE 1000
    GoTo mainloop ' Do it forever
    any ideas of maybe where i went wrong
    thanks
    crazy cooter
    IF ITS STOCK IT WONT ROCK
    The fact that you're getting 85°C is a good sign.
    That's the power-on default for the temperature registers of the DS1820. So at least you know the hardware is working.
    My guess is that the "READ POWER SUPPLY" line is not allowing the "start conversion" to work. Try it with that line commented out.
    <br>
    Nov 2006
    Exclamation
    i have tried it without the READ POWER SUPPLY. I have also tied a 4.7k resistor from the DQ line to 5V. Am i initialising it correctly??? This was a direct copy from melabs using "onewire.bas"
    Jul 2007
    Maryland, USA
    Did you set internal osc?
    Right after you compile, the screen comes up to program the chip. if you click view -> configuration. You can set INTOSC.
    a place I've tripped up before, just a thought.
    hope it helps
    Try changing this;
    to this;
    OWIn DQ, 2, [temperature.LOWBYTE, temperature.HIGHBYTE, Skip 4, count_remain, count_per_c]
    I beleive you need mode 2 after the last read to issue the reset pulse so the sensor
    is ready for the next on return to the start of your program.
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    I had to try it out, but all I have is a DS18B20.
    The original code worked fine, except I had to change the formula. But the communications seems OK.
    <br>
    Nov 2006
    Smile
    ok have got it to work. i replaced the 4k7 resistor with a 2k4 resistor and rererererereread the data sheet for the ds1820 and put a pause 750 after the start temp conversion. IE.
    OWOUT DQ,1, [$CC, $44]
    PAUSE 750 ' Max conversion time
    OWIN DQ, 4, [count_remain]
    i found it on pg 20 under AC Electrical Characteristics temperature conversion time
    i found its not as fast as i would have thought. is there any other way to make it faster or is this the speed of using the 1 wire devices
    the code
    TRISA = %11111111
    ADCON1 = 1
    PAUSE 1000
    DEFINE LCD_RSBIT 3
    DEFINE LCD_EBIT 2
    DEFINE LCD_BITS 4
    DEFINE LCD_LINES 2
    lcdout $fe, 1
    mainloop:
    pause 750 'NEEDED FOR TEMP STABILIZING
    LCDOut $fe, 1, DEC (temperature / 100)," C"
    thanks
    crazy cooter
    Hmmm, something doesn't seem right.
    The lower value pull-up, and pause 750 shouldn't be needed.
    The OWIn DQ, 4, [count_remain] will check the busy bit until the conversion is complete.
    ..... Unless it's running on "Parasite Power". In which case you need a Strong Pull-up on DQ during the conversion, and you can't read from the device for 750ms.
    If that fixed your problem, then you probably don't have 5V on pin 3 of the 1820.
    And if "Parasite Power" was intentional, you may need to do things differently.
    <br>
    Nov 2006
    Thumbs down
    Hi everyone
    Well this ds1820 ic is being a real pain. have gone over things with a multimeter and i have 5v going to pin 3. data is pin 2 and gnd is pin 1
    This is what the front of the ic looks
    ________
    dallas
    ds1820
    0634C3
    +552AC
    ________
    1 2 3
    GND 5V
    DATA
    2k4 resistor tied between pin 2 and pin 3
    I did notice "Vpu" figure 1 page 2 of the data sheet. What is Vpu is that the 5v line as i am using it. I assume it is. Could this be the problem??
    Am BALD cause of this ic. hahaha
    Yes, Vpu is VDD or +5V.
    If you have time, can you try this...
    Done      VAR BIT
    Parasite  VAR BIT
    Family    VAR BYTE
    Diag:
        OWIn DQ, 4, [Done]
        LCDOUT $FE,1,"Done =", bin1 Done
        OWOUT DQ, 1, [$CC, $B4] ' READ POWER SUPPLY
        OWIn DQ, 4, [Parasite]
        LCDOUT $FE,$C0,"Power="
        if Parasite = 0 then
            LCDOUT "Parasite"
            LCDOUT "VDD"
        OWOUT DQ, 1, [$33]
        OWIN  DQ, 2,[Family]
        LCDOUT $FE,$89,"FAM=",IHEX2 Family
        PAUSE 1000
    goto Diag
    Just stick it before the main loop in your program.
    Ideally, you should see this on the LCD ...
    Done = 1  FAM=$10
    Power=VDD
    <br>
    Nov 2006
    Thanks darren you have been a big help.
    The program initialy comes up with
    Done =1 FAM=$10
    Power=VDD
    then half second later changes to
    Done =1 FAM=$10
    Power=Parasite
    crazy cooter
    Well, it's reporting the correct Family number so the communications is working.
    But as suspected, it's also reporting that there's no power on VDD Pin 3.
    Since you said you already verified that there is +5V on Pin 3.
    The only thing left, is to say that that particular part has a problem with it's power pin.
    Maybe it was plugged in backwards at some point along the way.
    The rest still seems to be working, I guess you can just use it in Parasite mode.
    But you may want to approach it differently than just a smaller Pull-Up resistor.
    HTH,
    &nbsp; Darrel
    Nov 2006
    Ok i i flipped the wires on the ds1820 around (PIN1=3 PIN2=2 PIN3=1)
    And now get
    Done =1 FAM=$FF
    Power=VDD
    When i put a 10K pullup resistor on i get
    Done =1 FAM=$10
    Power=Parasite
    when i take the resistor away i get
    Done =0 FAM=$00
    Power=Parasite
    I flipped the ic around and get these readings
    Done =1 FAM=$FF
    Power=VDD
    Done =1 FAM=$FF
    Power=VDD
    Does anyone have these problems?
    Regards CC
    Nov 2006
    Thumbs up Its A Goer
    Thanks To Everyone Who Gave Me Advice Here. It Ended Up Being Two Dead Ds18s20. I Got Some New Ones Now And Its All Working Well.
    Crazy Cooter
  1. Using input from Switch to control a loop
    Last Post: - 2nd February 2009, 06:02
  2. Loop with two motor and 2 sensors
    Last Post: - 9th December 2008, 00:40
  3. Optimizing DIV
    Last Post: - 22nd September 2008, 05:58
  4. 16F88 Compile error
    By Toley00 in forum mel PIC BASIC Pro
    Last Post: - 2nd November 2005, 01:22
  5. Compiler/Assembler Error
    By LT_Pic in forum General
    Last Post: - 21st July 2005, 10:47
