IR Remote Control Issues
Results 1 to 21 of 21
    Perth, Australia
    These are the specs on my IR LED:
    Parameter                   min    typ    max   unit     test conditions
    radiant power               14     -      28    mW/cd2   If=20mA
    peak emission wavelength    -      -      940   nm       If=20mA
    spectral line half width    -      -      50    nm       If=20mA
    forward voltage             -      1.2    2.0   V        If=20mA
    reverse current             -      -      100   uA       Vr=5V
    rise time                   -      -      200   nS       PW=10uS DC=10% Ifp=20mA
    fall time                   -      -      500   nS       PW=10uS DC=10% Ifp=20mA
    power dissipation           -      -      150   mW       Vr=5V
    continous forward current   -      -      50    mA       -
    peak forward current        -      -      1     A        PW=10uS DC=10% Ifp=20mA
    reverse voltage             -      -      5     V        -
    viewing angle               -      20     -     deg      -
    operating temp range        -45    +25    +100  degC     -
    storage remp range          -45    +25    +100  degC     -
    lead soldering temp         -      -      +250  degC     5 Sec 1.6mm from base
    PW=Pulse Width
    DC=Duty Cycle
    The frequency of 48khz i found by trial and error. It def works best at 48khz.
    How could i get 700mA with this LED? Pref with 5v only?
    Dec 2005
    I've never heard of a 48kHz carrier. 32-40kHz is common and there are some that use ~56kHz What is the make/model of the TV?
    Perth, Australia
    Ok, I just tried it with a 10 ohm resistor, so 340mA through the LED. It only seems to have made a very small difference to the range, and I still have to point the LED *directly* at the TV for it to work - Even a few degrees make a difference.
    I will try playing with the frequency again.
    Also, do you think 50% duty cycle is the best bet? I wasn't sure what to use, and 50% seemed logical, but now i'm considering a lower duty cycle as that means the LED should theoretically be able to handler a higher peak current.
    *edit* My TV is a Samsung LA40R71BDX
    *edit2* Fixed mistake in schematic (thanks keithdoxey)
    Mar 2006
    China
    Default What protocol do you use?
    http://www.sbprojects.com/knowledge/ir/nec.htm
    Someone said Samsung uses NEC code 38 kHz with a dutycycle around 0.25 to 0.33
    HOW IS YOUR TIMING?
    Increasing IR current that much would have made a difference if that was the true problem.
    Do you have a scope so you can meassure the output of the TV remote control LED? (and if you have a nice digital one you might even post the pic)
    /me
    Perth, Australia
    I dont have scope unfortunately. So what I did was hook up an IR receiver to a PIC, and had it sample it every 10uS and output it to my PC which I then put into excel and made a graph. The pic attached has the signal from my TV's remote at the top, and the signal from my home made remote below. The scale on the bottom is in 10's of uS.
    As you can see, the timing is pretty close. I would have thought if it was a timing issue, it simply wouldn't work at all instead of bad range?
    I'm going to try 38khz at 25% and see how that goes.
    Dec 2005
    Samsung uses 38kHz and sends a 32-bit code similar to the NEC protocol but with a shorter lead-in pulse and with the bits interpreted differently. Samsung uses a 4.5mS start pulse followed by a 4.5mS space. Your example appears to be for the "1" key.
    Perth, Australia
    Sounds exactly like what i've observed. Do you know of a page on the net somewhere that has more detailed info on the protocol they used? I havn't been able to find any info on it.
    Mar 2006
    China
    Default What IR receiver did you use?
    When you PIC-scoped the remote what receiver did you use? What is the range and sensitivity using the standard tv remote control and this receiver?
    Then we can get an idea of the FQ used. If you have good distance with the remote then it must be your LED that has a major output power problem. It might be burnt due to over current along the evolution chain.
    Have you tried to move one thansistor to the base of the other, so you do all the mixing on the base.
    Maybe just loose both transistors and sink current with the PIC and make a software mixer by turning on and off HPWM (and connect the led there with a resistor)
    what partnumber is the led?
    what part number is the receiver you have used?
    /me
    Dec 2005
    Quote Originally Posted by Kamikaze47 View Post
    I don't recall seeing any detailed description. There is a simple description at http://www.techdesign.be/projects/011/011_waves.htm and there are CCF codes on RemoteCentral.com and at http://ir.premisesystems.com/. There are a few detailed descriptions of the NEC protocol. It was the first and was copied with minor changes by many others. Here's a datasheet for an early NEC encoder chip - http://davehouston.net/Nec6121.pdf
    EDIT: BTW, I find it easier to record the codes as .wav files using a soundcard. This way you can use a wave editor to view them. See http://davehouston.net/learn.htm
    OTOH, if you sample with a PIC using a phototransistor, you can get the carrier frequency and eliminate any guesswork.
    This technique should help you get a substantial improvement; instead of gating the LED using HPWM and a data pin, use the data pattern to control the HPWM pin itself (keep the HPWM running all the time, and just turn the HPWM pin to an input wherever you dont want a transmission); Darrel had suggested this during an earlier post pertaining to X10 transmission and it worked like a charm.
    If nothing else, it would at least eliminate the drop across one transistor, and you would save a pin as well. You would also find the waveform far more consistent with the original remote.
    Anand
    Just realised; if my math is right, you are *not* getting 340 mA thru' the LED with a 4.7K bias resistor; I would reduce that to 1 K; at the most 2.2 K.
    Anand
  1. Replies: 17
    Last Post: - 12th April 2014, 03:17
  2. Plz help in completing RC-5 IR remote lamp dimmer project
    By vu2iia in forum mel PIC BASIC Pro
    Last Post: - 3rd April 2008, 09:44
  3. No one-way approach to learning ir remote control frequencies
    By selbstdual in forum mel PIC BASIC Pro
    Last Post: - 22nd June 2007, 14:26
  4. IR Remote Control
    By mychangl in forum mel PIC BASIC Pro
    Last Post: - 25th March 2007, 08:01
  5. Digital Camera Controller
    Last Post: - 25th October 2005, 02:08
