Ok, here's what i've done since the description in my original post:
- Changed the LED's resistor to 10 ohm
- Removed one transistor, turning on and off PWM to control the LED
- Changed the frequency to 38kHz
- Changed the duty cycle to 25%
- Improved the timing using TMR0 for timing instead of PAUSEUS
The end result is an improvement, but not spectacular. The range is improved, however I still need to point the LED pretty much directly at the TV for it to work - Whereas i can point my normal TV remote anywhere in the room and it will work (even pointing directly away from the TV).
Perhaps I need some kind of diffusing material in front of the LED? I'm not sure what to use tho. Or maybe I need to get an LED with a better viweing angle, but i'm not sure that this is the case, unless my tv's remote has a 360 degree viewing angle - lol. I assume that my tvs remote is simply powerful enough to bounce off the walls and eventually find its way to the tv no matter what direction i point it.
