You can not do PWM and have constant voltage. PWM will go from ZERO to HIGH voltage.
If you have a voltage source of 14.2 for a 12 volt battery and the voltage source is switched via PWM at say a 50% duty cycle, the typical meter will read 7.1 volts. This will take twice as long to charge as the battery is only receiving the needed voltage for half the time. The argument for this is a slow charge is better than a fast charge.
I have seen some of those professional chargers that will read close to the 14 volts with a meter implying a peak voltage well above the maximum limit. (remember the UPS example). The amperage will also be on the high side too. The argument for this is that the average voltage going to the battery is correct.
The image you uploaded.
The LM350 is good for 3 amps (if memory serves ) with a good heat sink. The Could switch between two or change the adjust resistance for float voltage.
Is this for a back up system?
