Reading large data via RS232
Results 1 to 9 of 9
    Jul 2007
    Bavaria
    Hi Rob,
    if you want your program to reiceve the 2k of characters and then store them to the FRAM, you would have to buffer them in the RAM.
    Which PIC are you using currently?
    Ingo
    Hangover, Germany
    Cool
    If you want to receive 2k Data inside two start-stop-signs, you can't use one PBP-command, you have to write a programm !
    like this:
    Repeat
    Read 1 character
    Until this is the start-character
    ende=0
    repeat
    Read 1 character
    if "this is the end"? then
    ende=1
    store the character
    until ende=1
    And don't forget to use the hardware-UART !
    Jun 2007
    Germany
    I have an USART MAX232. Itīs on my dev. board included.
    I know how you mean to realize that, but i have to trigger the RX Channel with the incoming data from the computer? I use 9600Baud = 960 Bytes included start & stopbit.
    I think without serin commands can it be difficult to catch the bytes for the right time, maybe the input will shift for many bits!
    Hangover, Germany
    Cool
    Quote Originally Posted by Robson View Post
    No !
    The MAX232 isn't a USART. The USART is a part of the PIC. Just look, if the Rx- and Tx-Pins are propperly used.
    No,
    after activating the USART, it will receive any character.
    Yes,
    every second !
    Without using HSERIN it will be impossible !
    You have 1/960 seconds to store a character.
    Writing to a EEPROM needs 10ms (10 times more) to complete the write-cycle.
    You have to store the data in RAM.
    If you are good - you can write 1 page (maybe 128 Bytes) to a serial eeprom and start the write-cycle and maybe 15 characters later you can start to submit the next page, so you must only buffer 15-30 characters.
    Using hardware-USART with interrupts will be much better.
    Jun 2007
    Germany
    I prefer to use FRAMīs. Then there will no troubles about writing to eeprom.
  1. Using Nokia LCD
    Last Post: - 3rd May 2018, 04:47
  2. Read/Write Problem
    Last Post: - 10th February 2010, 01:51
  3. Big characters on HD44780 4x20
    Last Post: - 7th January 2007, 02:21
  4. LCD + bar graph
    Last Post: - 5th October 2005, 14:50
  5. Sinus calculating !
    Last Post: - 28th November 2004, 23:56
