Parallax RFID Reader code example
Results 1 to 5 of 5
    Sep 2007
    Waco, Texas
    Default Re: Parallax RFID Reader code example
    Hello All-
    I am trying to use the example given above in Dan-Tron's post but using different PIC but I am having trouble. I can read from the Parallax reader and display the info on the LCD but when it gets to the actual compare it breaks down. Even when it reads and compares all 10 chars.
    I have stared and work with this all weekend and I have added remarks and hopefully enough data so if anyone spots where I am a complete loser and can't see the problem I would appreciate it very much.
    The full code is listed below:
    '*  Name    : RFID.PBP                                                *
    '*  Authors : Steve Scott                                             *
    '*          : All Rights Reserved                                     *
    'Design Notion
    'Ver 0.1 - initial code
    'wait for $0A then recieve either 10 bytes of data or stop once it recieves $0D, which ever comes first.
    'tag var BYTE[10] ' Creates a byte array of 10 bytes
    'SERIN Rx, T2400,[WAIT ($0A),STR tag\10\$0D]
    '$0A-digit1-digit2-digit3-digit4-digit5-digit6-digit7-digit8-digit9-digit10-$0D
    '2400 baud, 8 bits, no parity, 1 stop, least significant bit 1st.
    'Want to 'enroll' new cards to be authorized from a central location and broadcast updated card information
    'via a mesh network around the house.
    'PROBLEMS-
    'I can read the card just fine (I think) and I can read the EEPROM location for all of the stored cards
    'BUT, when I do it with the compare it does not work.
    'I put an LCD on the system to see information because I used a serial port to interface a USB (FT232RL)
    'and I don't seem to be able to get serial data to a realterm client on the Win 7 PC (no hyperterminal in Win7).
    'I have debugging information as REMarked statements where applicable - maybe this will jar my brain......
    'Processor used is Microchip PIC18F8680 running 40Mhz oscillator.
    'RFID is Parallax serial unit
    'Using PBP3 GOLD and MicroCode Studio
    'MPLAB USB programmer
    'Internals Overview:
    'Assign address values for all of the configuration registers for the purpose of table reads
    '_DEVID1         EQU    H'3FFFFE'   ' This is hardcoded by manufacturer to indicate processor info
    '_DEVID2         EQU    H'3FFFFF'   ' This is hardcoded by manufacturer to indicate processor info
    'I like this new command!
       __CONFIG    _CONFIG1H, _OSC_ECIO_1H & _OSCS_OFF_1H
    ; Oscillator switching not enabled, EC w/OSC2 as RA6
       __CONFIG    _CONFIG2L, _PWRT_ON_2L & _BOR_ON_2L & _BORV_45_2L
    ; Brown out enabled at 4.5 volts, power-up timer enabled
       __CONFIG    _CONFIG2H, _WDT_OFF_2H & _WDTPS_1_2H
    ; Watchdog timer disabled with postscaler = 1:1
    ;   __CONFIG    _CONFIG3L, _MODE_MC_3L & _WAIT_OFF_3L
    ; Disable external wait for table functions, set to microcontroller mode
       __CONFIG    _CONFIG3H, _MCLRE_ON_3H & _ECCPMX_PORTE_3H & _CCP2MX_OFF_3H
    ; Use /MCLR instead of as RG5, Set ECCPMX, CCP2MX to Port E
       __CONFIG    _CONFIG4L, _STVR_ON_4L & _LVP_OFF_4L & _DEBUG_OFF_4L
    ; Turn off debug pins, stack full/underflow will cause reset
    ;Not used - @ __CONFIG    _CONFIG4H,
       __CONFIG    _CONFIG5L, _CP0_ON_5L & _CP1_ON_5L & _CP2_ON_5L & _CP3_ON_5L
    ; Code Protect On for all of memory (Blocks 0 - 3)
       __CONFIG    _CONFIG5H, _CPB_ON_5H & _CPD_ON_5H
    ; Code Protect On for all of memory (EEPROM and Boot)
    ;'@   __CONFIG    _CONFIG6L, _WRT0_ON_6L & _WRT1_ON_6L & _WRT2_ON_6L & _WRT3_ON_6L
    ; Flash program memory protect On for all of memory
    ;'@   __CONFIG    _CONFIG6H, _WRTB_ON_6H & _WRTC_ON_6H &  _WRTD_ON_6H
    ; Flash program memory protect On for all of memory (EEPROM, Boot and Config Register)
    ;'@   __CONFIG    _CONFIG7L, _EBTR0_ON_7L & _EBTR1_ON_7L & _EBTR2_ON_7L & _EBTR3_ON_7L
    ; Disable Table Read protection
    ;'@   __CONFIG    _CONFIG7H, _EBTRB_ON_7H
    ; Disable Boot Block Table Read protection
    ;Set ID Bits For Automatic Configuration
    ;    __IDLOCS    _IDLOC0, $49      ; Configure ascii to say 'Imagine!'
    ;    __IDLOCS    _IDLOC1, $6D      ;
    ;    __IDLOCS    _IDLOC2, $61      ;
    ;    __IDLOCS    _IDLOC3, $67      ;
    ;    __IDLOCS    _IDLOC4, $69      ;
    ;    __IDLOCS    _IDLOC5, $6E      ;
    ;    __IDLOCS    _IDLOC6, $65      ;
    ;    __IDLOCS    _IDLOC7, $21      ;
    'Add INCLUDE files here...................
    include "modedefs.bas"
    ' Define Declarations
    DEFINE OSC 40                                   ' A 40MHz oscillator is used for this processor
    ' LCD stuff here
    DEFINE LCD_DREG     PORTJ
    DEFINE LCD_DBIT     0
    DEFINE LCD_RSREG    PORTG
    DEFINE LCD_RSBIT    3
    DEFINE LCD_EREG     PORTJ
    DEFINE LCD_EBIT     7
    DEFINE LCD_RWREG    PORTG
    DEFINE LCD_RWBIT    4
    DEFINE LCD_BITS     4
    DEFINE LCD_LINES    4
    DEFINE LCD_COMMANDUS 2000
    DEFINE LCD_DATAUS   50
    PAUSE 300                                       ' Stop 300ms
    ' DEBUG stuff here even though it does not seem to work with the USB bridge
    define DEBUG_REG PORTC                          ' Sets the serial/USB bridge output to PORTC
    define DEBUG_BIT 6                              ' Sets the output to bit 6 - TXD
    define DEBUG_BAUD 9600                          ' Sets baud
    define BEBUG_MODE 0                             ' Sets 0=true or 1=inverted
    ' Constant Declarations
    ' Alias Declarations
    STAT1       VAR PORTA.6                         ' STAT1 Status LED - active high
    STAT2       VAR PORTA.4                         ' STAT2 Status LED - active low
    RFID_en     var PORTA.5                         ' Low ENABLES reader
    RFID_data   var PORTB.1                         ' Serial data from reader
    Lock        var PORTB.0                         ' Controlled lock
    Lock_LED    var PORTA.4                         ' System ready
    ' -----[ Variables ]-------------------------------------------------------
    x           var byte                            ' Junk counter variable
    buf	        VAR	byte [10]                       ' RFID bytes buffer
    cardNum     VAR	Byte	                        ' from EEPROM table
    idx	        VAR	Byte	                        ' card byte index
    char        VAR	Byte	                        ' character from table
    ' -----[ EEPROM Data ]-----------------------------------------------------
    'The card data was taken from reading and displaying the card data on the LCD
    'Reads and compares only the 1st 8 chars
    card1	DATA	"5400826125"
    'Reads and compares only the 1st 2 chars
    card2	DATA	"6500017041"
    card3	DATA	"0603222230"
    card4	DATA	"6500021219"
    'Reads and compares ALL 10 chars
    card5	DATA	"5400819186"
    ' Jump to program initialization
    GoTo Initialization
    ' Start program execution by initializing all required variables and machine states
    Initialization:
        'Hookay Boyz, here we go again!
        LCDOUT $FE, $01                             ' Initialize the LCDOUT function for PBP
        LCDOUT $FE, $80                             ' Go to the first character position of the first line
        LCDOUT "Initializating...   "               ' Write text on first line
        LCDOUT $FE, $C0                             ' Go to the first character position of the second line
        LCDOUT "                    "               ' Move cursor to 2nd line and write text
        stat1=1
        INTCON = 0                                  'Disable all interrupts and clear all interrupt flags
        TRISA.4 = 0                                 'Set all externally accessible mainboard I/O ports, this is an OUTPUT
        TRISA.5 = 0
        TRISA.6 = 0
        TRISB.0 = 0
        TRISB.1 = 1
        TRISC.5 = 1
        TRISG.1 = 1
        TRISG.3 = 0
        TRISG.4 = 0
        TRISD = $FF
        TRISE = $FF
        TRISF = $FF
        TRISH = $FF
        TRISJ = $0                                  ' Set as OUTPUTS
        ADCON1 = %00111011                          'Set AN0 - AN3 to be the only analog inputs, External VRef+/VRef
        CMCON = %00000111                           'Turn off Comparator for PortF.1 & PortF.2
        PSPCON.4 = 0                                'Turn off Parallel Slave Port functionality on Port D
        CCP1CON = %00000000                         'Turn off CCP1 function
        CCP2CON = %00000000                         'Turn off CCP2 function
        ' Setup the main system loop timer
        T0CON = %01000000               'Set Timer 0 to disabled, 8-bit operation, internal ClkOut clock, prescaled as
                                                            'constant'd above
        INTCON.5 = 0                                        'Disable the interrupt for the main system loop
                                                            'timer (Timer 0)
    ' -----[ Port Initialization ]--------------------------------------------------
        stat1=0
        stat2=1
        high rfid_en                                ' turn off RFID reader PORT A5 is the reciever port
        LOW lock                                    ' lock active
        high lock_led                               ' Turn off LED
        goto Main
            lcdout $FE,1,   "     READY          "
            low lock_led                            ' Turn ON door LED
            low rfid_en                             ' activate the reader
            SERIN2 rfid_data, 396, [WAIT($0A),STR buf\10]
            high lock_led                           ' Turn OFF door LED
            high rfid_en                            ' deactivate reader
            for idx=0 to 9
                lcdout $FE,$80+idx, hex1 buf[idx]
            next idx
            lcdout $FE,$80+12,"CARD"
    'At this point we have sucessfully displayed the read card
    Check_List:
            FOR cardNum= 5 to 5                     ' scan through known cards - OR USE AS A DEBUG
                for idx=0 to 9
                    read (((cardNum-1)*10)+idx), char
                    lcdout $FE,$C0+idx, char
                next idx
                lcdout $FE,$C0+12,"EEPROM"," ",dec1 cardnum
    'At this point we sucessfully display the 1st line is the read card 10 digits
    'The second line is the 1st EEPROM value
                FOR idx= 0 TO 9		                        ' scan bytes in card
                    READ (((cardNum-1)*10)+idx), char	    ' get card data from table
                    lcdout $FE,$94+idx, char
                    lcdout $FE,$94+12,"COMPARE"
                    lcdout $FE,$D4,  "B4 compare, idx=",dec1 idx
                    IF (char <> buf(idx)) THEN BadChar		' compare card to table
    'This seems to be where it breaks down.  I can read from EEPROM and can read a card
    'but I don't seem to get this to work.
    'On some cards it gets only 2 chars then breaks to a new cardNum and thus data
    'On a TAG it will read all 10 chars but NEVER falls through to the CARDFOUND label!
    'It flows on to BadChar and since there is no other card it falls through and says
    'INVALID CARD - even if it reads and compares ALL 10 chars - like the last card!!
                NEXT idx
    'I never get to this next line even if it reads and compares ALL 10 chars!!!!!
                lcdout $FE,$D4,  "@ last idx,CARDFOUND"
                pause 2000
                GOTO CardFound			               ' all bytes match!
    BadChar:					                       ' try next card
            NEXT cardnum
    BadCard:
            FREQOUT PORTC.5, 1000 */ $100, 115 */ $100	' groan
            lcdout $FE,$D4,  "Invalid CARD        "
            pause 5000
            GOTO Main
    CardFound:
            HIGH lock   				                ' Open lock
            low lock_led				                ' Light LED
            FREQOUT PORTC.5, 2000 */ $100, 880 */$100	' beep
            LOW lock    				                ' Reset lock
            high lock_led				                ' LED OFF
            GOTO Main
    Stop		' Kill the program if it gets this far
    "If we knew what we were doing, it wouldn't be called research"
    - Albert Einstein
    Just a guess, do you need a PAUSE after READ?
    Sep 2007
    Waco, Texas
    Thanks Robert. It ended up not being a PUSE after a READ but it was the bad data I was getting from the LCD - maybe it was too slow - I don't know.
    Out of desperation, I used the SEROUT as a DEBUG since the DEBUG doesn't seem to work with a USB bridge.
    I used the SEROUT data and it worked 1st time!
    Thanks for the help and interest,
    Regards!
    - Albert Einstein
  1. Proximity Reader (Weigand) aka RFID
    By GoldStar in forum mel PIC BASIC Pro
    Last Post: - 23rd May 2009, 05:41
  2. Loop with two motor and 2 sensors
  3. Replies: 3
    Last Post: - 12th March 2008, 05:33
  4. parallax rfid reader module interface with PC
    By jonil22 in forum Off Topic
    Last Post: - 3rd February 2008, 06:54
  5. Serial interface with RFID reader
    By brid0030 in forum Serial
    Last Post: - 23rd January 2007, 06:23
