LCDOUT with custom PINS
Results 1 to 12 of 12
    Default Now i am working.... late?
    Hi, i didnt reply because i was expecting the PCB, it was late so i got to work just today.
    Darrel Thanks for your reply, i have been trying to figure your suggestion, i get the virtual port, but in the link
    http://www.picbasic.co.uk/forum/showthread.php?p=22065
    the example to use it to this specific case uses a HighJack.bas include that isnt posted anywhere.
    Now if i get it well The HighJack.bas file must be used to replace a subroutine for a self made one, wich DO is on the post.
    Now summary: The HighJack will replace LCDOUT for a selfmade, this LCD self made uses virtual PORT to write to the device.... If i am wrong please correct me.
    Finally i will need HighJack.bas
    On the other hand, is it really this hard to work with LCD`s isnīt there a simple routine that i can change just to make LCDOUT? which are the LCD commands?, i have never seen them.
    DJC
    Hi Josuetas,
    It really depends on what you need to do with the LCD.
    If you just want to send individual characters to the LCD, you can use the program shown in the other thread, and by removing the HighJack reference and changing 1 other line, it will do exactly that. Which means the answer to the question is ... No it's not difficult to work with LCD's.
    But that means you can't use PBP's LCDOUT statement. No DEC, HEX, STR, or anything else that goes with LCDOUT.
    The hard part, is making a "custom LCD Driver" tie into PBP's LCDOUT statement so that it's completely transparent to the user. You would just use LCDOUT like you normally would.
    Like I mentioned earlier, I have it working here. But I still haven't got it to where I can release it as "Working in all situations".
    I'm sure I can get it working for you, but I want to do some testing here first. So I need to know EXACTLY what your setup is.
    Originally you said 16F628.
    Is that the standard or "A" version?
    Are these correct?
    Hopefully
    PortA.6->D7
    PortA.7->D6
    PortA.0->D5
    PortA.1->D4
    And what about RS and E ?
    OK, too slow.
    You're probably in another timezone sleeping away..
    Got it figured out.
    See this ...
    LCD_AnyPin.pbp
    http://www.picbasic.co.uk/forum/showthread.php?t=7038
    HTH,
    Default Sorry for the daley
    I am sorry for being late in my answer
    Thanks for your help Darrel, i will watch it right now.
  1. Timer + rc5
    By naga in forum mel PIC BASIC Pro
    Last Post: - 19th November 2009, 08:56
  2. need help in coding..
    By daphne8888 in forum mel PIC BASIC
    Last Post: - 19th March 2008, 08:31
  3. Help GPS read with serin
    By leinske in forum mel PIC BASIC Pro
    Last Post: - 5th September 2007, 03:33
  4. Crystalfontz LCD
    By jman12 in forum mel PIC BASIC Pro
    Last Post: - 9th February 2007, 16:04
  5. having problems with Hantronix 20x4 lcd
    By Rhatidbwoy in forum mel PIC BASIC Pro
    Last Post: - 22nd December 2005, 13:22
