This tool is only for flashing a pic?
You can only set the config fuses for the PIC nothing else.
Take a look at the datasheet for your PIC and you will solve your problem.
Look here : http://freenet-homepage.de/dl4yhf/wi...tm#config_bits
Thanks Robson,
I use WINPIC mostly and PicKit2 when I'm stuck, like now.
Even PicKit2 generates an error "Programming failed at Program Memory Adress 0x00000D".
I just bought those two PICs and doubt they are dead since I never used them before.
I'll have a look at the "Config2" word. Maybe, this will help.
Would you have more detailed info about this, I would appreciate.
Roger
