Error - Fatal Out Of Memory ( With Array)
Results 1 to 2 of 2
    Aug 2007
    Default Error - Fatal Out Of Memory ( With Array)
    Hi all
    I have this error compiling my program (PIC16F84A)
    INCLUDE "modedefs.bas"
    OUTPUT PORTB.4
    OUTPUT PORTB.5
    OUTPUT PORTB.6
    OUTPUT PORTB.7
    VALOR_DISP var byte[4]
    VALOR_DISP[0] var PORTB.4
    VALOR_DISP[1] var PORTB.5
    VALOR_DISP[2] var PORTB.6
    VALOR_DISP[3] var PORTB.7
    ERROR:
    FATAL OUT OF MEMORY (pbpw.exe)
    This code is for send to array (VALOR_DISP) a 4-bit (0010) code for 7-segment display
    and sendit to pins
    I test my program per parts, and in variable declarations VALOR_DISP[x] VAR PORTB.x
    the program crash.
    I dont write any code after this ( fortest purpose ). Only this minimal code get this error
    Whats happens guys ????
    Jun 2007
    Germany
    You cannot define
    VALOR_DISP var byte[4] as BYTE
    VALOR_DISP var PORTB.4 and in the same time as an ALIAS.
    You should use an other Variablename for aliasing a PORTPIN.
    Last Post: - 14th June 2016, 08:55
  2. Simple Array Demo
    By Archangel in forum Code Examples
    Last Post: - 15th February 2010, 05:46
  3. RS232 receive an array (packet)
    Last Post: - 12th February 2008, 06:02
  4. Need the code to write to a memory
    By Hamlet in forum General
    Last Post: - 20th August 2007, 01:22
  5. Replies: 4
    Last Post: - 2nd March 2007, 07:12
