Need help converting to ASCII Hex format
Results 1 to 10 of 10
    Dec 2003
    San Diego
    Default Stored in a variable
    Quote Originally Posted by Robson View Post
    Where is your data stored ?
    Variable or EEprom or something else?
    It is in a variable... not in EEprom or from a serial source.
    Tcbcats
    Jun 2007
    Germany
    Try this
    B0      VAR BYTE
    B1      VAR BYTE
    B2      VAR BYTE
    B3      VAR BYTE
    BWord1  Var BYTE
    BWord2  VAR BYTE
    BWord   VAR WORD
    VarWord VAR WORD
    VarWord = 1389 ' Here is your number you defined
    B3 = VarWord DIG 3
    B2 = VarWord DIG 2
    B1 = VarWord DIG 1
    B0 = VarWord DIG 0
    BWord1 = B3 * 16 + B2
    BWord2 = B1 * 16 + B0
    BWord = BWord1 * $100 + BWord2 ' Here stands your Word like 1389 as hex
    Lightbulb
    Value     VAR WORD
    Buf       VAR BYTE[3]
    DigLoop   VAR BYTE
    Value = 01389
    For DigLoop = 5 to 1 STEP -2
        Buf((6-DigLoop)/2) = ((Value DIG DigLoop) << 4) + Value DIG (DigLoop -1)
    Next DigLoop
    LCDOUT HEX2 Buf(0),":",HEX2 Buf(1),":",HEX2 Buf(2)
    Displays 00:13:89
    Jun 2007
    Germany
    Darrel something is not going in my head.
    Value = 01389 ' <- Is the "0" really included ?
    The compiler will ignore any leading 0's.
    That's the way Tcbcats showed it, so I left it in there.
    Jun 2007
    Germany
    @Darrel
    i mean this line.
        Buf((6-DigLoop)/2) ' = Buf((6-5)/2) = 0.5 ??? Does it really works? Round it to zero?
    Next DigLoop
    I don´t tried it out, maybe it works
    Sure it works.
    But PBP uses integer math. So there are no decimals.
    With STEP -2 the loop will execute 3 times, with the values 5, 3, 1 in DigLoop.
    Since it's Integer math, (6-DigLoop)/2 will return 0, 1 and 2 respectively.
    loop    Buf((6-DigLoop)/2) = ((Value DIG DigLoop) << 4) + Value DIG (DigLoop -1)
    5       BUF(      0      ) = (       $00              ) +        0  = $00
    3       BUF(      1      ) = (       $10              ) +        3  = $13
    1       BUF(      2      ) = (       $80              ) +        9  = $89
    hth,
  1. Hex converting
    By Andre_Pretorius in forum General
    Last Post: - 26th June 2009, 02:48
  2. hex ascii help please
    By ffr58kk90 in forum mel PIC BASIC Pro
    Last Post: - 29th December 2006, 21:09
  3. Converting ASCII to HEX
    Last Post: - 27th September 2006, 10:21
  4. ascii characters to hex
    By Peter1960 in forum mel PIC BASIC Pro
    Last Post: - 26th January 2006, 04:06
  5. Converting Bytes from hex to Dec
    By Rob Martin in forum mel PIC BASIC Pro
    Last Post: - 8th April 2005, 19:44
