The most used configuration for serial communication is 8-N-1.
Data bits: 8
Parity: None
Stop bits: 1
This will produce a frame with 10 bits.
Frame:
< 1 start bit >< 8 data bits >< 1 stop bit >
So in order to send one byte with the above configuration you will need 10 bits.
Therefore at 9600 baud you can send 960 bytes per second.
9600 / 10 = 960 bytes per second.
Best regards,
Luciano
