Hi C.C.,
this might be an opportunity to use select case.
I noticed you are using IF THEN to direct functions for each state or your PortA.2 inputs, why not use ELSE ?
HTHCode:main: If PortA.2 = 0 then gosub waterok ELSE Gosub Waterbad if PORTA.6 = 1 then ' assumes you have pulldown resistor GOSUB tempdown if PORTA.7 = 1 then 'assumes you have pulldown resistor GOSUB tempup ENDIF endif endif goto main waterok: lcdout $fe, $c0+13, " OK" return waterbad: lcdout $FE,$c0+13, " NASTY" return tempdown: lcdout $fe, $80+0, "TEMP DOWN " RETURN tempup: lcdout $fe, $80+0, "TEMP UP " RETURN END
JS
