if-then statements
Results 1 to 5 of 5
    sinoteq's Avatar
    sinoteq Guest
    Look at what you have written and you will see why it does not work. Here is a short hint.
    MAIN:
    lcdout $fe, $80+0, "PUMP off GAS off"
    lcdout $fe, $c0+8, "WATER"
    if PORTA.2 = 1 then GOTO waterok
    if PORTA.2 = 0 then GOTO waterbad
    if PORTA.6 = 1 then GOTO tempdown
    if PORTA.7 = 1 then GOTO tempup
    PAUSE 500
    GOTO MAIN
    waterok:
    lcdout $fe, $c0+13, " OK"
    The problem is that you jump back to main all the time so in this case you will not do the other IF statements. This is why we have GOSUB in PBP, it jumps to a SUB and when you use RETURN you will jump back to the line after..... More or less in any case.
    SO
    MAIN:
    if PORTA.2 = 1 then GOSUB waterok '<------------------- JUMP if true
    if PORTA.2 = 0 then GOSUB waterbad
    if PORTA.6 = 1 then GOSUB tempdown
    if PORTA.7 = 1 then GOSUB tempup
    PAUSE 500
    GOTO MAIN
    waterok:
    RETURN '<------ to exit the SUB and return to MAIN
    Get the idea??
    M
    Hi C.C.,
    this might be an opportunity to use select case.
    I noticed you are using IF THEN to direct functions for each state or your PortA.2 inputs, why not use ELSE ?
    If PortA.2 = 0 then
    gosub waterok
    Gosub Waterbad
    if PORTA.6 = 1 then ' assumes you have pulldown resistor
    GOSUB tempdown
    if PORTA.7 = 1 then 'assumes you have pulldown resistor
    GOSUB tempup
    waterok:
    waterbad:
    lcdout $FE,$c0+13, " NASTY"
    tempdown:
    lcdout $fe, $80+0, "TEMP DOWN "
    tempup:
    lcdout $fe, $80+0, "TEMP UP "
    HTH
    JS
    How about;
    MAIN:
        lcdout $fe, $80, "PUMP off GAS off"
        if PORTA.2 = 1 then
           lcdout $fe, $c0+13, " OK "
           lcdout $fe, $c0+13, " BAD"
        if PORTA.6 = 1 then lcdout $fe, $80, "TEMP DOWN       "
        if PORTA.7 = 1 then lcdout $fe, $80, "TEMP UP         "
        PAUSE 500
        GOTO MAIN
    And maybe: if (PORTA.6=1) AND (PORTA.7=1) then lcdout $fe,$80," FAT FINGERS "..;o}
    -Bruce
    tech at rentron.com
    http://www.rentron.com
  1. How much code space do PBP statements use.
    Last Post: - 13th February 2009, 22:31
  2. Multiple IF-THEN statements
    By DavidK in forum mel PIC BASIC Pro
    Last Post: - 20th June 2007, 19:28
  3. Proton Commands & statements
    By Lotondo in forum mel PIC BASIC Pro
    Last Post: - 7th November 2006, 00:37
  4. time for PBP statements
    By fnovau in forum mel PIC BASIC Pro
    Last Post: - 25th October 2006, 20:42
  5. If - then statements
    Last Post: - 18th May 2006, 23:57
